Hi guys,
For sale: Apexi AVC-R Electronic Boost Controller (Model number S-AVC2)
Price and price conditions: $350 ono
Condition: Great Condition
Pictures: Will post up later today
Contact Details: PM, reply here or 0424144525
Delivery & Conditions of Delivery: Willing to post. Buyer pays postage
Am looking to sell my Apexi AVC-R. Has all wiring, solenoids etc. Don't have the original box but will package up well if someone wants it posted. Instruction Manual is easy to find online.
Unit is mounted to an Apexi stand but that hasn't been mounted to anything so not ruined. Wiring has spade connecters on end for easy connection/disconnection to wiring as I didn't know if I would run this or not. Decided not to and going for a Nistune and see what the Tuner wants to run in it.
Thanks for looking
https://www.sau.com.au/forums/topic/418856-apexi-avcr/
Item 2:
For sale: S13 Coilovers JIC Front/Unkown rears
Price and price conditions: $450 ono
Condition: There is apparently a knock in one of the fronts. Other than that I believe the coilovers are in good condition.
Pictures: Below
Received these when I purchased my S13. Seller advised that one of the fronts was knocking so took them out. I have put them in the garage and haven't even touched them since. I believe they are fine except for the knock. Fronts are JIC and the rears don't have stickers to identify them. Will go out and take photos of them now.
AVCR by Peter Mackellin, on Flickr
Coilovers 1 by Peter Mackellin, on Flickr
Coilovers 2 by Peter Mackellin, on Flickr
https://www.sau.com.au/forums/topic/418856-apexi-avcr/#findComment-6727932
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
