Yeh man already got an exhaust happing thanks anyways! Any other ideas?
Read the RB25 results thread and also the modifying thread to get a feel for upgrading your car....
The first stage is pretty limited with your injectors, but an ECU and Cooler etc will allow you to raise the boost a rad, thats about all you should need to do for the initial mod :) (Ecu not essential but factory ECU doesnt like boost increase in a lot of cases)
https://www.sau.com.au/forums/topic/418880-r34-gtt/#findComment-6729517
rb 20 actuator. for 10psi goodness.
better dump and front pipe. high flow cat.
front mount cooler. all can be had for a total of 500 bucks if you look hard enough.
now with an auto, you will need a stage two shift kit and an oil cooler for the transmission. thats gonna be 650 upwards for all that paid for and fitted.
then its fuel pump, injectors. 300+ bucks
ecu, safc 2 is your cheapest bet. 200 upwards.
then turbo. cheapest is highflowing yours. 880 bucks.
tune on a dyno to set it up. god knows. but all that should see about 220+kw at your wheels. with the auto.
(just going off the same pattern as mine but mine is an r33)
https://www.sau.com.au/forums/topic/418880-r34-gtt/#findComment-6729532
HEAPS of good tuners for ECU upgrade, but you need the ECU and a tune, they are not plug in as such.... I have had good dealings with JEM and also DVS JEZ but there are other good names floating around the forums like UNIGROUP and a heap of others, shop around and choose the one you are happy with!
https://www.sau.com.au/forums/topic/418880-r34-gtt/#findComment-6730000
Yeh sweet well ima get a fmic first and then ill go after the ecu and a tune. And then go from there! :) keen as!!!
make sure you get advice about a suitable ecu.
you need a piggy back not a full replcement on a 33 auto. not aure about 34.
https://www.sau.com.au/forums/topic/418880-r34-gtt/#findComment-6730095
Yeh i just need to look around ive read a couple threads just need to find one that is compatiable with a 34 auto :)
i think you have a seperate ecu for your box that cuts timing when it changes gear. so you should be cool. but double check that.
if you dont the best you can get is a greddy emanage ultimate.
https://www.sau.com.au/forums/topic/418880-r34-gtt/#findComment-6731528
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
