Hi There South Aussies!
Just wondering if my old R32 is still around, down Adelaide way.....
It was bought from me here in Sydney by a young bloke named Samir in 2009, who was from Adelaide.
It was a gunmetal grey R32 GTS-t type M without the side/rear skirts or wing, it was fitted with the following:
Standard wheels
HKS pod filter
3inch S/Steel catback exhaust with no intermediate muffler
Clear front indicators, with the bulge out fitted with orange globes & wired to the park lights (VERY hard to miss!)
HID Xenon headlights
Nismo variable rate springs, 4 point adjustable dampers & castor arms
Nismo 260 km/hr cluster (bought brand new 0k's, had nearly 9,000 on it when I sold it)
2 1/16" ultralite Autometer boost gauge mounted on the steering column
Blue LED dash kit including boost gauge, underdash front foot well & under front seats for rear footwells
Panasonic chrome headunit with remote & pioneer speakers behind stock speaker grilles
Momo steering wheel
Original Dealer sticker above rear tow hook (in pics)
Met up with Samir in Adelaide just after I sold it to him. Only changes it had were a P plate in the window & a GTR badge on the boot?!?
Would love to find out what happened to my old pride & joy, as it was very clean, & I'm sick of wondering about it!!!!!!
Pics attached!!!!!!!
post-90018-0-23079100-1359548396_thumb.jpg post-90018-0-70640400-1359548411_thumb.jpg
post-90018-0-07811600-1359548435_thumb.jpg post-90018-0-29063800-1359548447_thumb.jpg
post-90018-0-58174600-1359548467_thumb.jpg post-90018-0-12212200-1359548506_thumb.jpg
https://www.sau.com.au/forums/topic/418909-has-anyone-seen-my-old-r32/
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
