Hey guys im still having heaps of issues with my R32 GTR. Anyway first it had a stalling problem and the other day I was driving and as usual it stalled, few days later I started her up and she died straight away, when I finally got her started she was idling and revving really rough and won't rev over 3k and blows a shitload of black smoke and I've just noticed that there white smoke coming from the turbo's side.
Would my turbo's be blown? Or motor maybe?
https://www.sau.com.au/forums/topic/418920-r32-gtr-turbos-smoking/
Black smoke = running rich, which will happen a bit because the standard tune is quite rich, especially if you have wound the boost up. It will also run very rich if you have an air leak and youre boosting (or at least the turbos are attempting to boost). You wont make much power if you have any decent sized air leak. Usually this sort of stuff is not that serious.
White/blue smoke = oil burning, this is usually more serious. Can be from oil leaking past turbo seals, or past valve stem seals or past piston rings.
So, first couple of things;
- Check engine oil level
- Look for air leaks. Could be a split intercooler hose (one of mine just did this) or loose connection. Probably not a hose coming off because you would typically get a bit of a pop when it comes off, but still check for it.
- If you make no boost at all (ie it goes from vacuum to 0 but not past it) you have an air leak or blown turbo. Its pretty much always the rear turbo that blows. If the turbo has blown you will see ceramic turbine bits trapped in front of the cat, so you could drop it to check for that. It just looks like bits of rock.
- After that, a compression test may be worthwhile
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
