  • Replies 69
I drove Darksky's 34 and thought it felt normal to be honest. Probably taken it higher in the rev range than he has :D
Comparing it to a pretty stock 33 i didn't feel / hear any issues :D
haha well that problem is solved then :P
    • Holy hell! That is absolutely stunning! Great work!!!
