Hi guys,
I have a R34 GTT which was recently nistuned running 13psi on stock turbo with FMIC etc mods.
The car ran great a week after tune, then I took it for a long run up to Lancelin and noticed some pretty bad misfire in high revs.
While I was there I decided to clean the AFM gently with some rubbing alcohol. The misfire seems to have dissappeared however now the car has lost roughly half it's power on full boost past 3-4 rpm.
The turbo spools to 13psi as normal, and there is a loud intake noise however roughly half the power it should. I assume if it was a boost leak it would splutter and give out black smoke however this is not the case.
Curious to know if anyone knows if this is a typical symptom of a damaged AFM or something else like timing issue etc? Many thanks.
https://www.sau.com.au/forums/topic/418949-does-this-sound-like-a-damaged-afm/
Would take it back to where you got it tuned and let them give it the once over to make sure everything they adjusted is in check.
Also check your coil-packs. My car wouldn't like high revs under boost. Put a set of yellowjackets in there and hey presto, no misfire.
Booked into workshop next month, I'm going to check the coil packs and spark plugs while I wait.
It's getting worse now, holding down accelerator on full boost - the car literally lurches backwards from lack of power, and then splutters on idle briefly.
Yeah within a week of me going to a highflow/injectors/powerfc/etc my coil packs let go... Misfiring under boost / higher rpm... I got some Splitfires and it's been perfect ever since
Also make sure that your spark plugs are fine, could be that the tune is slightly off and they have fouled after a while?
I sprayed it with a pump spray cleaning alcohol, didn't actually touch the components.
Anyway I have replaced the spark plugs with no difference.
I took it for a drive and it's worse. It seems to really drop power at high revs/boost in a sort of shuddering kind of way, and repeats this shuddering in "waves" as you keep your foot down.
Th3 coilovers are spitfires so I didn't think they would damage easily??
Anyone know what his may be?
Did you use the same plug type at the same gap? If there's more gap then you've made it harder for the coils to make the spark, and it will make any ignition related missfire worse.
What gap are you running now?
Hi guys thanks for the replies.
My previous plugs had 0.9mm gap so were the new plugs.
I took out the spit fires and put in a spare set of stock coils with no difference, either it's not the coils or plugs or both sets of coils were faulty.
I will find another AFM to test, no idea if a damaged AFM produces symptoms like this.
Hi Mate,
I am experiencing the same symptoms and i was also wondering if it was the AFM. Mine however doesn’t hesitate it just has a flat spot between 4000-5500rpm and then lunches fine after 5500rpm. Almost like it has no energy and then decides to go. Can R&R be caused by a faulty AFM?
If its braking down and misfiring under boost/load at higher rpm then I'd say coil packs. If you're hearing a loud induction noise then maybe one of your FMIC pipes/hoses has popped off and leaking boost BUT still seals up when off boost. Might pay to re check and re tighten.
And when you are cleaning your AFM I'd recommend a break cleaner or carbie cleaner in a spray (and one that comes with a straw nosil.) That shit dries to nothing and doesn't leave a oily residue like some 'parts washers'
Good luck!!
Hi GTR_NUTZ thanks for your reply.
It seems everyone is saying coil packs so I guess I need to go in that direction and buy either a set of new spitfires or OEM coilpacks. I guess I was naive thinking that the spitfires would never fail on me.
Pretty sure it isnt a leaking hose/pipe as I have checked thoroughly.
SKY338 I am not sure but I may try to get my hands on a spare AFM in any case to test.
    • Ha ha ha, mine loves to spend, all on the dogs (they're our kids, and her spending would likely rival that of some people raising children!) the only benefit is, her spending is tax deductible as she runs a business in the dog industry 😛 The above all means she can spend race car budget quicker than I can. 😛 That and a lot of the things I want are very expensive, and I can be a bit "you want how much for that?!" And at other times overly impulsive. Or I start the w days of research, get to day 1.5 and get really annoyed that no one will advertise actual specifics and it's just marketting BS and I go "well, now I don't want anything to do with that now!" Also I hate paying lots of money for something I can make from $50 in materials. Then I get the shits halfway through making things and wonder why others who just buy parts have more fun... 😛
    • Their 240Z with the RB26 would be a real nice thing to have in a garage to come out for an occasional weekend cruise It's such a cool thing in so many ways Sadly, we have a blue 240Z shell that I walk past every day, just sitting outside a shed at work, it has been slowly disintegrating and falling apart into the ground for the last few years, the owner cannot be found, and I am unable to "claim it" I've been told by work and the RMS, the rust in the body is excessive though, and it has had most of the salvageable stuff, like panels, trim and switch gear stripped off it over the last year or two, work keeps threatening to put it in one of our metal scrap bins, I wish they did though, as it makes Mark sad walking past it
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
