Hi guys,
I have a R34 GTT which was recently nistuned running 13psi on stock turbo with FMIC etc mods.
The car ran great a week after tune, then I took it for a long run up to Lancelin and noticed some pretty bad misfire in high revs.
While I was there I decided to clean the AFM gently with some rubbing alcohol. The misfire seems to have dissappeared however now the car has lost roughly half it's power on full boost past 3-4 rpm.
The turbo spools to 13psi as normal, and there is a loud intake noise however roughly half the power it should. I assume if it was a boost leak it would splutter and give out black smoke however this is not the case.
Curious to know if anyone knows if this is a typical symptom of a damaged AFM or something else like timing issue etc? Many thanks.
https://www.sau.com.au/forums/topic/418949-does-this-sound-like-a-damaged-afm/
Would take it back to where you got it tuned and let them give it the once over to make sure everything they adjusted is in check.
Also check your coil-packs. My car wouldn't like high revs under boost. Put a set of yellowjackets in there and hey presto, no misfire.
Booked into workshop next month, I'm going to check the coil packs and spark plugs while I wait.
It's getting worse now, holding down accelerator on full boost - the car literally lurches backwards from lack of power, and then splutters on idle briefly.
Yeah within a week of me going to a highflow/injectors/powerfc/etc my coil packs let go... Misfiring under boost / higher rpm... I got some Splitfires and it's been perfect ever since
Also make sure that your spark plugs are fine, could be that the tune is slightly off and they have fouled after a while?
I sprayed it with a pump spray cleaning alcohol, didn't actually touch the components.
Anyway I have replaced the spark plugs with no difference.
I took it for a drive and it's worse. It seems to really drop power at high revs/boost in a sort of shuddering kind of way, and repeats this shuddering in "waves" as you keep your foot down.
Th3 coilovers are spitfires so I didn't think they would damage easily??
Anyone know what his may be?
Did you use the same plug type at the same gap? If there's more gap then you've made it harder for the coils to make the spark, and it will make any ignition related missfire worse.
What gap are you running now?
Hi guys thanks for the replies.
My previous plugs had 0.9mm gap so were the new plugs.
I took out the spit fires and put in a spare set of stock coils with no difference, either it's not the coils or plugs or both sets of coils were faulty.
I will find another AFM to test, no idea if a damaged AFM produces symptoms like this.
Hi Mate,
I am experiencing the same symptoms and i was also wondering if it was the AFM. Mine however doesn’t hesitate it just has a flat spot between 4000-5500rpm and then lunches fine after 5500rpm. Almost like it has no energy and then decides to go. Can R&R be caused by a faulty AFM?
If its braking down and misfiring under boost/load at higher rpm then I'd say coil packs. If you're hearing a loud induction noise then maybe one of your FMIC pipes/hoses has popped off and leaking boost BUT still seals up when off boost. Might pay to re check and re tighten.
And when you are cleaning your AFM I'd recommend a break cleaner or carbie cleaner in a spray (and one that comes with a straw nosil.) That shit dries to nothing and doesn't leave a oily residue like some 'parts washers'
Good luck!!
Hi GTR_NUTZ thanks for your reply.
It seems everyone is saying coil packs so I guess I need to go in that direction and buy either a set of new spitfires or OEM coilpacks. I guess I was naive thinking that the spitfires would never fail on me.
Pretty sure it isnt a leaking hose/pipe as I have checked thoroughly.
SKY338 I am not sure but I may try to get my hands on a spare AFM in any case to test.
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
