Hi guys,
I have a R34 GTT which was recently nistuned running 13psi on stock turbo with FMIC etc mods.
The car ran great a week after tune, then I took it for a long run up to Lancelin and noticed some pretty bad misfire in high revs.
While I was there I decided to clean the AFM gently with some rubbing alcohol. The misfire seems to have dissappeared however now the car has lost roughly half it's power on full boost past 3-4 rpm.
The turbo spools to 13psi as normal, and there is a loud intake noise however roughly half the power it should. I assume if it was a boost leak it would splutter and give out black smoke however this is not the case.
Curious to know if anyone knows if this is a typical symptom of a damaged AFM or something else like timing issue etc? Many thanks.
https://www.sau.com.au/forums/topic/418949-does-this-sound-like-a-damaged-afm/
Would take it back to where you got it tuned and let them give it the once over to make sure everything they adjusted is in check.
Also check your coil-packs. My car wouldn't like high revs under boost. Put a set of yellowjackets in there and hey presto, no misfire.
Booked into workshop next month, I'm going to check the coil packs and spark plugs while I wait.
It's getting worse now, holding down accelerator on full boost - the car literally lurches backwards from lack of power, and then splutters on idle briefly.
Yeah within a week of me going to a highflow/injectors/powerfc/etc my coil packs let go... Misfiring under boost / higher rpm... I got some Splitfires and it's been perfect ever since
Also make sure that your spark plugs are fine, could be that the tune is slightly off and they have fouled after a while?
I sprayed it with a pump spray cleaning alcohol, didn't actually touch the components.
Anyway I have replaced the spark plugs with no difference.
I took it for a drive and it's worse. It seems to really drop power at high revs/boost in a sort of shuddering kind of way, and repeats this shuddering in "waves" as you keep your foot down.
Th3 coilovers are spitfires so I didn't think they would damage easily??
Anyone know what his may be?
Did you use the same plug type at the same gap? If there's more gap then you've made it harder for the coils to make the spark, and it will make any ignition related missfire worse.
What gap are you running now?
Hi guys thanks for the replies.
My previous plugs had 0.9mm gap so were the new plugs.
I took out the spit fires and put in a spare set of stock coils with no difference, either it's not the coils or plugs or both sets of coils were faulty.
I will find another AFM to test, no idea if a damaged AFM produces symptoms like this.
Hi Mate,
I am experiencing the same symptoms and i was also wondering if it was the AFM. Mine however doesn’t hesitate it just has a flat spot between 4000-5500rpm and then lunches fine after 5500rpm. Almost like it has no energy and then decides to go. Can R&R be caused by a faulty AFM?
If its braking down and misfiring under boost/load at higher rpm then I'd say coil packs. If you're hearing a loud induction noise then maybe one of your FMIC pipes/hoses has popped off and leaking boost BUT still seals up when off boost. Might pay to re check and re tighten.
And when you are cleaning your AFM I'd recommend a break cleaner or carbie cleaner in a spray (and one that comes with a straw nosil.) That shit dries to nothing and doesn't leave a oily residue like some 'parts washers'
Good luck!!
Hi GTR_NUTZ thanks for your reply.
It seems everyone is saying coil packs so I guess I need to go in that direction and buy either a set of new spitfires or OEM coilpacks. I guess I was naive thinking that the spitfires would never fail on me.
Pretty sure it isnt a leaking hose/pipe as I have checked thoroughly.
SKY338 I am not sure but I may try to get my hands on a spare AFM in any case to test.
    • He obviously had his reason for flipping you off. I wonder what it was...
    • Thats why I stay far, far away from Eastwood. only go there if I wanna eat Korean food
    • I have to agree like, yesterday, I was driving down the warringah freeway towards the bridge when this jackass driving a beaten up Honda civic cut me off so suddenly it made me almost yank the wheel to avoid him hitting my car. Honestly and he had the NERVE to flip me off (or some other gesture Idk). Im a calm guy, but really some people just dont deserve to have a license, let alone be allowed to drive on densely populated roads/highways. If youre gonna cut through lanes at least use the damn turn signal
    • HPA do an interesting video on tuning, and Adrian shows on the dyno, moving from 10:1 to 12:1 (And I think even 13:1) and the power moves SFA. However, a couple of degrees of timing has a HUGE impact. Exhaust side of things will more be the length of the exhaust and how many bends and turns you have. The straighter you can keep it, the better. By a lot. Oh, and getting the diameter right. Bigger isn't always better. Going to big can actually lose you power.
    • I have to say, most people I see on the road fit the bill of atrocious drivers. Whether they be cowboys in their dual cabs, bogans in the Commodores, or the soccer mums. Pretty much most people on the road put zero freaking thought into driving. Barely look further up the road then the end of their bonnet, and have never even thought about how catastrophically wrong shit can go, by doing what they all deem as normal driving. Especially their late braking, racing to stopped lights, and sitting half a foot off the bumper of the car in front at 110km/h. Wanna know what's even better? By the time their kids get to be old enough to learn to drive, they've already got in the back of their brain what is normal driving, how annoyed you're allowed to get at people etc, and then their parents who actually have zero freaking skill at driving (Even though they constantly say "I've been driving for 20 years and never had an accident!") teach the little twerps how to drive, or should I say, how to make a car move. Literally watched a parent teach their L Plater, on a 4 lane freeway, that you just slam the brakes on, and push your way over, even with a B Double bearing down on you, and that's how you should drive, rather then, just keep going to the next exit. Same shit happens all the time for side streets etc, watching numpties pull dumb shit turns pushing across 3 lanes of traffic, rather than just go up the road another 30 seconds, and take the next turn that'll get you to the same location... Oh, and the damn right lane bandits. Or the retards driving along with their headphones in, and can't hear the ambulance or fire truck right up their ass about to run them over...   Pretty much, people drive on the road, like ego centric f**ks, and don't actually think how dumb shit their driving is, how it could easily kill them or someone else in a split second, or at the very least, how they're driving is contributing to all the shit they're bitching about on the road, like shitty congestion!
