“Rbn1” R32 Gtr - 7 Years In Storage – Time To Restore And Rebuild.
Racepace Full Exhaust Sound Video. Phone is pretty close to the exhaust and you can still hear the engine belts etc.
Smoke on startup was from from me false starting it just before. Screech after startup is from starter motor starting to play up.
Revving to 3k then 4k.
  • Like 1
sounds tough man really like it.........gave me an idea to do the same ;)
  • 3 weeks later...
Just to dig up an old pic
Where/who did you get this lip from? I like the lights idea
Bought it off a member on here. It's a custom job with a series of led lights that someone has hooked up. Wouldn't be too hard to do just time consuming .
I'll probably remove the lights and just fill it up, though as the lights wouldn't be ADR approved to be used as brake lights.
Have found some time to get some more work done on the interior. A lot of the interior trim damaged from the roll cage as been replaced.
In the process decided to change a couple of standard bits. Found a seller on eBay (from UK) selling some leather bits and pieces so decided to give a few things a go while i'm assembling the interior.
Interior leather trim covers.
Had to get these stuck on with spray on adhesive and then trimmed very carefully with a stanley knife.
All done.
Fitted onto the car with all plastic clips replaced with new items.
If you look closely in this photo you can see the holes from the roll cage are visible. Will be putting the plates back on as an interim solution.
Leather passenger side handle cover (Velcros to the handle)
Carbon Centre Console Cover. This was a bitch to get on with self adhesive and I stuffed up the trimming of it a bit.
Am sure this will add at least 5kw by the time i'm done.
Also changed over the head unit and put some temporary 5" Response kevlar speakers into the front doors. Car's not a boom box but I gotta have something in there to listen to when I get her road registered and am stuck in Melbourne traffic I guess.
Going into Xmas I hear that Santa (in the form of the Missus) will be buying me some more interior pieces currently missing or damaged and some after market bits.
Hot tip for those with partners : 1. Load up your online part shop shopping carts with parts you want. 2. Tell your significant other, your login details and ask them to buy them as presents.
Still have to fix the drop in boost so got a hold of a standard intercooler for cheap.
All paint stripped now.
Considered polishing it briefly but I'm going to put a mesh over the front bar anyway.
Back at Racepace for it's first (1000k) service, re-tune with the new intercooler and a few other minor things while it's in there.
  • Like 2
RP don't see a problem with the current location of the Oil cooler so it will remain where it is.
Hey mate, was having another flick through your thread and saw this - my oil cooler was mounted in a very similar spot until last month when I was at the racetrack and nicked the ripple strip with the oil cooler. Only put a hole that was max 2mm in diameter but had to shut the motor down and tow the car home as I emptied a fair amount of oil. Had to buy a new oil cooler which I've now positioned in front of the radiator - never want that to happen again and would hate for it to happen to others as for such a small hole it caused me big dramas!
Interesting. We figured that if it managed to hit the oil cooler then the whole front floor of the car must be hugging the floor so i'd have bigger problems than just the oil cooler by then :)
Going by the below pic is your one mounted the same as mine, also how low is your car?
Thanks for the heads up, I'll get them to take a look at it while it's in.
I went out to the car tonight and took a pic, looks like it was bolted to the same bar that yours is. The car also isn't massively low, I've attached a couple of pics to show the location and the height!
Anyway, just thought I'd share my experience as something to bear in mind :)
Thanks for that, good information. I'll get the location changed before I do a track day!
Paint stripping the front mount intercooler looks awesome!
I too did the same.
Looking forward to see the result with the OEM Intercooler.
  • Like 1
Hope everyone had a great Christmas. Car has had to spend the Christmas and New Years at the workshop as the seals for the leaking ABS pump are no where to be found in the country atm.
Santa was kind this year. Got new replacement left and centre vents to replace the usual broken old ones on 32's and some minor clips and screws that were missing.
Also got some Superior Auto Creative Carbon-Look Sun Visor Cover set to cover up the tatty OEM ones.
Plan early next year is to start preparing the car for the engineers certificate and registration. Items to do before hand include repair underbody holes from roll cage and some minor body repair including some dodgy roof damage repair that was present when I first got the car. (will post pictures when I get her back)
Have a great new years everyone!
  • Like 1
  • 4 weeks later...
First update for 2014 - Car has had to spend all the holidays plus some at the workshop due to the pesky seals for the ABS pump being no where to be found.
Have replaced the pump with a second hand one for the time being so hopefully this one doesn't link.
Got bored waiting for the car so re-trimmed the front doors cards with leather covers to match the rears.
All the standard underbody plastic guards are back on including the OEM brake ducts. Still needs to be re-tuned with the replacement intercooler. Hopefully can pick it up this weekend. Itching to put all the interior bits in and start work to get it ready for registration.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
