Aussie VIN number - done
High Mount Brake light - done.
A few other ADR items like tyre placard, fuel filler neck, unleaded only fuel sticker etc also done.
It's been a good start to the weekend so far. Godzilla is 25 years old this year. That means - Club Permit!
Finally road legal after 9 years of arriving down under.
  • Like 3
Looks great and gets better every Pic
where did you get the high mount brake light from and are you happy, is it secure enough ?
I bought one similar and the first hot day the double sided tape let go :( (POS)
Edited by Sinista32
Thanks mate.
Light is a Narva 84650BL. Came with 3M double sided tape & the LED's can be angled. Hope it isn't the same one you tried that fell off :)
Autobarn stocks them.
http://www.narva.com.au/products/browse/eye-level-brake
I tried to get a Hella 5237 multiple times from the local Repco but gave up as they didn't get back to me multiple times.
Thanks - *nervous look* It is the exact same one and they're ADR approved. I bought it from Repco.
may have been the way I applied it though I did use prepsol on the glass first. It was about 38 degrees and in the sun all day. So a 50/50 chance.
If it does fall off on a hot day Wurth make a brilliant industrial strength double sided tape. :thumbsup:
Hmmmmm. I'll see how I go with it. I'm planning to replace it with the Hella down the road anyway
Thanks for the tip. Is the Wurth double sided tape good for side skirts etc too?
Do tell :)
race tune.
Currently on my setup I'm making 350kw at 20-22psi on the -9s with 98pump fuel
This is the everyday tune that is also safe on the track as I track my car a lot now
I have been told by my tuner there is more in them but not with 98
E85 maybe this year but I do daily my car, just got a new car for daily duties this month so we shall see
There is heaps of potential in these turbos if your setup is good enough, they won't crack 400 but when you have full boost by 3800rpm who cares haha
Wow and I thought I was up at odd hours on this forum :)
Something to consider (and this has been done to death on here), the only way to truly compare is to have the cars on the same dyno, on the same day, with the same wheel/tyre combo. At the end of the day 350rwkw is awesome on -9's.
btw do you have a dyno graph of your final run?- I'm more curious about the boost curve on these turbos as I know my setup was modified to hold more boost so wanted to see what they do on the top end on different setups.
On night shift this weekend ?
Yea I know all dynos are different and tyres blah blah
Numbers don't mean much to me all I wanted was something reliable with some power
I'll find the dyno sheet and post it up
They do drop off in the top end, that's just how the turbos are
Edit
329 run
B904E5CD-A205-4487-AB5D-DFBD41AF5104-568
350 run with stuffed cat screwing the top end, will go for another run next service I think
8A48BB11-9718-4233-9092-94AC91FB0942-568
Edit
329 run
Nice. What gear - 3rd?
Ditch the cat :)
Loving this build. Keep us updated!
Thanks mate. Will do :) Still so much to do!
Went down to Apollo Bay yesterday with an old mate of mine. Covered around 500km's and she ran well all day, even through the unsealed roads we came across accidentally. Got to pretend it was a rally car for a short while. They both got a tad dusty.
1913442_10151983953867734_1189276120_o_z
Livin the dream, You didn't go down Wild Dog Road, just before the entrance to Apollo Bay did you? Love that Road.
Also, are you planning on coming on the SAU Apollo Bay Cruise in a couple of weeks?
Hah! Yes we did :)
I now understand why it's called Wild Dog Road.
Hmm possibly, man.
It's a bit rough but an awesome drive. Great views once you get to the top.
Looking forward to it. It'll be the 1st time I've taken the car down the GOR since I bought it.
Hi Shivam, I'm the guy from Perth who approached you & your mate while you were resting up in Apollo bay on Sunday.
Found your build thread you were telling me about - good work! It was nice chatting to you fellas. I'm definitely missing my car after a few months away from home as you could probly gather by the way I chewed your ears off!
Enjoy the car after all the hard work mate. You never know I may meet you again later this year if the SAU Nats are held at Phillip Island!
Wes
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
