IMO get an OEM R32 GTR steering wheel for street and just swap that Sparco wheel on for when its tracked. OEM all the way.
Agreed. OEM one is pretty good.
Finding one that isn't shagged is another thing :)
Have a look into Nardi Steering wheels.
I got one.
Always wanted an OEM steering wheel.
Simple / looks clean and does the job.
But I got a Nardi, can't complain, I guess.
I'll take a geezer.
I rather like that Sparco one as it does feel great to use.
Like I said, I have been quietly getting work done on a replacement......hopefully some sneeky pics soon! :)
  • Like 1
don't be silly boys..........just get your original OEM steering wheel restitched
like this Robson leather - cost approx $300
you can get it with red stitching too ;)
  • Like 2
Some photos from the event.
1960881_10152054375322734_901571917_o_zp
1799982_10152054370092734_974164642_o_zp
Sun in my eye!
1781358_10152054498867734_1332399294_o_z
Black & White - PaulR32GTR's car after we had a Motorkhana battle. What an animal!
1891373_10152054438592734_346939167_o_zp
Car ran perfectly all day without a hitch. Very happy with it.
Possibly a hill climb next, followed by a track day but before that some changes coming next time she goes into RPM for a service.
  • Like 1
Sun in my eye!
very nice shivam. Love the rear end of them R32's
Paul's car is also sweet
  • Like 1
  • 1 month later...
Small and subtle update. Just got the car back from a service. Some minor things repaired/replaced here and there. Discovered that I had to get the rear drive shaft reconditioned. "Replaced centre bearing, machine flange to suit spicer 1350 universal, rebuild CV and replace boot, balance assy"
Shiny new driveshaft.
Now for the visually subtle but big change to the car. RPM transfer case mod. Transfer case has been rebuilt. Additional clutch plates and a few other changes internally, I believe. Also 4WD system modified, running more pressure.
Does it make a difference? Hell yeah! 4WD comes in sooner and harder and it's lost quite a bit of the 32 GTR "tail happy, laggy 4WD system" character. Have a Haunted Hills hill climb event coming up so can't wait to really test it out. Can't believe I hadn't done this mod sooner. Next stop, Nismo front diff!
  • Like 2
That is sweet Shivam.
Can you pm details on transfer case mod i.e. costs etc....
def sounds the way to go.
Nismo front diff - should also be another epic mod (although I will go with Quaife) :thumbsup:
Saw your Quaife diff. Win! Will make a big difference going from 3WD>4WD on these cars :)
RPM mentioned that they modify the Nismo diff a little bit before it goes in (didn't ask what at this stage)
PM on the way :)
  • Like 1
You'll most definitely appreciate the transfer case mod.
Running with new tyres at Winton on the weekend made it more apparent just how slow the 4WD system is from factory. Wheel spin city!
  • Like 1
Few changes to Victorian club permits around the corner and a few other things happening as well atm. Instead of doing lots of events over the next two years in full roll-cage trim, have decided to slowly change it to a full registered road car in the next few months.
Have had this sitting around for a while. Standard steering wheel with sewn on leather cover. Will go on after the Hill Climb event this weekend at Haunted Hills.
  • Like 1
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
