With SAU VIC Winton track day just around the corner I had the realisation that I needed to get the standard bootlid/spoiler setup back on stat.
Didn't have any time left so spent a couple of nights with $120 worth of paint supplies. Didn't expected a pro result but it'll get me by for the 2015 season at least.
Didn't turn out as bad as I thought it would be. (although I wish I had an effective way of baking the panels afterwards).
Orange peel galore atm. Will wait a couple of months for it to all harden properly before giving it a good polish.
Rear badge removed off the old fibreglass bootlid, cleaned up and 3M double sided tape applied.
Spent ages measuring and getting the badge on exactly in the right spot to the mm. (11mm from the bottom, 30mm from the right) - SAU to the rescue once again with that info. Lots of sweat involved in this task.
The photo of an 32GTR with factory bits isn't amazing to anyone but me....
For the first time in 10years since I've had the car. Rear spoiler! Spent quite a while looking at it, last night. <Sob>
Soooooo changes the look of the car.
The fibreglass boot lid that the car came with from Japan. Impressive quality and very light. Will be hanging onto this.
Next stop. Boot lip. The one I have has a few holes that need to be fibreglass, patched up so that will have to wait.
  • Like 2
  • 3 weeks later...
Some odd and ends from RHDJapan for some upcoming small projects.
Brake Line A Clamps, Sideskirt clips & Nice shiny new replacement door handles.
On a separate note, I finally measure the offset of the 17"s that came with the car.
+0 Offset TE37's. Figures why they filled out the guards so well for a 9" rim.
Hey, can you tell me what the part number is for the door handles please?
Cheers
  • 3 months later...
This shiz needs updates.
It does. I've lost momentum recently and this is why.
Leaving in the morning, earlier in the year in March. Winton Circuit Club Track day.
This is how the car left the March Circuit Club Winton track day. The motor didn't fare too well unfortunately.
Thanks to team gtr_jet for getting the car home. Would have been majorly screwed otherwise.
Sat on it for a couple of months then finally got it sent to Racepace.
Ahh the natural home of a raced GTR - on the back of a tow truck.
Racepace were nice enough to pay for tow back. Sitting back at home now in it's current state.
Least I get to paint the engine bay now, I guess.
I'll post up later on when I get time what we know so far. Guesses on what went wrong?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
