2 minutes ago, mr_rbman said:
you don't get any attessa issues running the wheel and tyre combo you do?!
Nope. I run the same size all round.
I have 2 sets of wheels
1st set   : Volk TE37 17x9” +0 Gloss Black – Falken RT615 : 255/40/17 (these wheels came with the car)
2nd set :  Volk TE37 18x9.5 +12 Satin Black – Yokohama AD08R 265/35/18
Was starting to get worried as everything was running so well.
Drove the car to work and back during a couple of high 30 degree days and on the way back on the second day, noticed a foul smell from the engine bay, in stop/start traffic.
Got home and couldn't figure out where it was coming from. Thought great, somethings curled up and died in there.
Noticed some strange corrosive spray marks around the battery and I found this - sealed battery is not so sealed anymore.
Managed to spill acid everywhere while I was trying to take it out.
Acid has eaten away at the paint underneath and new black silicone hoses and marked the hard pipes. Great.
Quite possibly overcharging due to regulator issue but PFC said 14.1V
Could also possibly have been the battery
Cleaned up as much as possible with water. Will need to sand back the exposed metal and re-paint.
What sort of battery to get next? No use keeping the battery here, in the engine bay.
Looks like there's a new project coming....
That battery wasn't sealed to begin with, i would recommend a Optima Yellow or Red Top battery, they are fantastic, better power per size then most batteries on the market, and completely sealed, you could install it upside down if you really wanted to.
  • Like 2
Ah ok.
I've tilted the battery before and it hasn't spilled, previously. Accord to Century they are sealed? http://www.centurybatteries.com.au/products/sealed-maintenance-free
Cool, thanks I'll take a look at those. Was also looking at Odyssey AGM's.
Will need to sort out details on the battery relocation.
Just get a full river sealed battery, have had much better run with them than oddesy or optima junk.
Find out what model Chris fits to them, not expensive either.
http://www.rjbatt.com.au/fullriver-hc-battery-range/
  • Like 1
21 minutes ago, RBN1 said:
Ah ok.
The plastic underneath the long sticker is a lid, on the back up the top you will find 2 x screwdriver slots to pop it up and the caps are under there. The new range of Century's batteries have gone maint. free
Odyssey are great batteries also, all comes down to your budget.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
