With SAU VIC Winton track day just around the corner I had the realisation that I needed to get the standard bootlid/spoiler setup back on stat.
Didn't have any time left so spent a couple of nights with $120 worth of paint supplies. Didn't expected a pro result but it'll get me by for the 2015 season at least.
Didn't turn out as bad as I thought it would be. (although I wish I had an effective way of baking the panels afterwards).
Orange peel galore atm. Will wait a couple of months for it to all harden properly before giving it a good polish.
Rear badge removed off the old fibreglass bootlid, cleaned up and 3M double sided tape applied.
Spent ages measuring and getting the badge on exactly in the right spot to the mm. (11mm from the bottom, 30mm from the right) - SAU to the rescue once again with that info. Lots of sweat involved in this task.
The photo of an 32GTR with factory bits isn't amazing to anyone but me....
For the first time in 10years since I've had the car. Rear spoiler! Spent quite a while looking at it, last night. <Sob>
Soooooo changes the look of the car.
The fibreglass boot lid that the car came with from Japan. Impressive quality and very light. Will be hanging onto this.
Next stop. Boot lip. The one I have has a few holes that need to be fibreglass, patched up so that will have to wait.
  • Like 2
  • 3 weeks later...
Some odd and ends from RHDJapan for some upcoming small projects.
Brake Line A Clamps, Sideskirt clips & Nice shiny new replacement door handles.
On a separate note, I finally measure the offset of the 17"s that came with the car.
+0 Offset TE37's. Figures why they filled out the guards so well for a 9" rim.
Hey, can you tell me what the part number is for the door handles please?
Cheers
  • 3 months later...
This shiz needs updates.
It does. I've lost momentum recently and this is why.
Leaving in the morning, earlier in the year in March. Winton Circuit Club Track day.
This is how the car left the March Circuit Club Winton track day. The motor didn't fare too well unfortunately.
Thanks to team gtr_jet for getting the car home. Would have been majorly screwed otherwise.
Sat on it for a couple of months then finally got it sent to Racepace.
Ahh the natural home of a raced GTR - on the back of a tow truck.
Racepace were nice enough to pay for tow back. Sitting back at home now in it's current state.
Least I get to paint the engine bay now, I guess.
I'll post up later on when I get time what we know so far. Guesses on what went wrong?
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
    • You're selling the SS?! How much are you asking on it?
    • My answer would be, that depends. If it's something that can be grumpy to start, runs a bit rich, and is likely an expensive engine, then yes, I would. But there's a few reasons why. Sumps aren't really sealed, there is airways to them, so it is technically open to moisture. Secondly, if as mentioned it has been started, and it's a fuelled up, I'd dump it, as chances are, fuel is in the oil. Next to that comes, how much use had said oil seen before it was parked up. IE, how much carbon, and potentially fuel/water did get in there while it was being used, and has now been allowed to sit, and slowly come together? For the most part, if it's just been something like a road car, stock engine, nothing wild, f**king send it if it's not near oil change spec.
    • I forgot to say Mark, you know how if you lack sleep, we get Grumpy Mark? When I lack sleep I'm Grumpy Matt. We must be the GrumpMa's!
