  On 30/08/2015 at 9:34 AM, Anfanee said:
Sad face. I know your pain man. I would go satin black.
Yeah not as much fun second time around. Still gotta look at it as an opportunity to fix a couple of things I should I have done last time.
  • 1 month later...
Dunno why I didn't get this done first time around. Been old and scratched since I got it. Fiddly and lot of prep, covering everything but worth it.
Satin Black. Drivers side, section done. Passenger side, firewall and radiator support still to do.
136AC0E4-5DD4-47E8-A945-596F2731A8E1_zps
6EDC9421-1C87-4A89-BB1F-8A85E6B05DEF_zps
76C865AD-4337-41E1-BF08-418F93FB2CC1_zps
  • Like 4
  • 2 months later...
  • 2 months later...
First update for 2016 - haven't neglected the car totally.
Baby steps...
Found a nice clean windscreen washer bottle in my parts bin to replace the ageing yellow one.
More importantly got busy with the rest of the engine bay and finally finished it all.
Didn't think there was much difference in the final result until, I did an A to B comparison.
So much time spent taking all the little clips and bits off and putting them back on....
A few +1's cleaned up too -
Painted in Satin Black : Transmission tunnel, injector resistor pack and bonnet stand
Painted in Gloss Black : Power steering reservoir.
The clips for the ABS lines will be replaced with brand new items I have here.
Next stop - paint & fit genuine Nismo rear pods.
  • Like 1
i love this shit! end result looks great. really cleans up the look of the bay. i did my strut tops recently but i didnt pull out as much as you did.
i also repainted my battery tray area as it was full of battery acid and surface rust. so much cleaner now.
  • Like 1
I was in Racepace for my first time ever Tuesday just been if Im correct, I believe your car was there, looks great mate top job
Hi mate,
nope wasn't mine :)
Still finishing little bits and pieces off slowly at home before giving it back to them.
Photo%2020-02-2016%209%2049%2044%20AM_zp
Speaking of finishes touches. Replaced the A-clamps for the hydraulic lines that go on the firewall, with nice new replacement items.
Checkout the colour difference between an old one and a new item. I've noticed 34R's have the same issue now that they're getting up there as well.
Photo%2020-02-2016%209%2045%2001%20AM_zp
There's just something very satisfying about putting brand new, oem bits in....
Photo%2023-02-2016%202%2033%2034%20PM_zp
Engine bay almost complete. Just have to clean up the replacement overflow bottle before putting it back in.
Photo%2020-02-2016%2012%2031%2026%20PM_z
Although the worn out paint on top of the headlights are now seriously bothering me. Anyone repainted their ones? If so what gloss high temp paint did you use?
I may wait until the motor is back in before getting this done. That way I can use the headlights to heat up and harden the paint.
Genuine Nismo rear rods painted. The only rubber Nismo body items for a 32R that don't suck.
Photo%2020-02-2016%209%2024%2055%20AM_zp
Am really glad I got my hands on these genuine items. Now to fit the suckers......
  • Like 3
  On 23/02/2016 at 5:56 AM, k_d said:
Im pretty sure i didnt use hi temp paint on mine, and it lasted well. I used wurth satin black if i recall correctly
OK, i'll give it a crack. I think the standard colour on there is gloss black?
Sunday - "Complete The +1's Session"
Decided to try satin black for the top of the headlights.
Came out pretty close to the standard colour.
Note I didn't take off all the old paint before spraying and one headlight, the paint bubbled up , and had to be re-done. So if you're going to try this, rub down the old paint, as you'll find it's just barely on there after so many years of heat.
Fixing all the little things like this makes a noticeable difference. Much neater. The GKTech air deflector and front grill are now calling out to me.
Cam Covers Packed and sent off to be powder coated. Lets see how I go with this.
Engine bay will look a lot better when the motor goes in this time around.
  • Like 1
Also got around to fitting the genuine Nismo rear pods
Felt like ground hog day doing this again.
Genuine items being rubber however are easier to fit and reach all the way to the rear bar unlike what the copies did.
Hard to tell the difference from these photos but they also mold a lot better around the body, being rubber.
  • Like 4
Just read all 24 pages from start to finish in the last two days.. Awesome thread!
Can't wait to see the engine back in that nice new bay :D
Keep up the good work man, love the thread
thanks, mate :)
  • 3 weeks later...
shivam, what did you use to attach these? sikaflex or double sided tape?
Hi mate,
3M Automotive double sided tape. Also 3 screws that go into the OEM locations, two in the wheel arch, behind the rear wheel and one underneath.
I've found the 3M tape to be more than enough. I had to cut the doubel sided tape used on the previous fibreglass copies with sharp guitar strings as it wouldn't come off without breaking the pods straight off.
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
