ITEM: RB26 bottom end built to handle big HP using top name Jap parts (specs below)
CONDITION: Excellent - parts are only 5,000kms old
PRICE: $9,000 bottom end; $2,000 external pump kit or $10,000 for both
CONTACT: PM - SERIOUS ENGUIRIES ONLY - NO TIMEWASTERS
OTHER: Engine made 722rwhp recently on moderate boost with zero blow by. 5,000kms were on low boost for run in and street driving . Will handle 10,000+ rpm & 1,000hp with the right head.
SPECS:
HKS Step 3 22mm pin pistons
Apexi V-MAX SPL rods
Apexi V-MAX SPL billet 73.7mm fully counterweighted crank
ARP main bolts
new water pump
Will also come with one spare piston and rings
$9,000
Optional:
External oil pump kit -
ATI race damper
Moroso external single stage wet sump
Petersen pulleys/mandrel
Mounting bracket and belt
modified oil pump housing
Sump with Trust extension and modified pick up to suit external
braided lines and fittings to suit
$2,000
Or $10,000 for both
Bottom end also comes with ARP head studs.
Moroso pump has previously been rebuilt, rest of gear is new with a few road kms and dyno runs done only.
Note: Won't separate external oil pump kit until engine is also sold as it is all still assembled.
  • 3 weeks later...
  • 1 month later...
