I'm just about to gain ownership of the d2 8pot 356mm big brake upgrade on the front of my r32 gtr, with the increased piston surface area at the front i'm guessing it will largely change the brake bias in my car? I understand that my gtr has 38mm pistons in the rear, and the (r32vspec, 33, 34) are an amolst straight bolt on with a larger 40mm rear pistion and slightly larger disc.
Would the larger brembo plus larger disc be worth my time or should i opt for some thing else, my car will see a fair bit of track work.
Also an upgrade in the master brake cyclinder would greatly help?
Thank you Elliot
Edited by geetea-are
Piston area has little to do with it. In fact, given that these calipers are intended to be put onto cars without any changes to the master cylinder (or necessarily any change to the rear brakes), I think you'll find that the 8 little pistons don't have a very different total area than the 4 bigger ones in your existing calipers.
The difference in braking power comes simply from the extra torque created by moving the contact circle radially outward from the hub. The same braking force applied to the disc multiplied by the longer lever arm = more torque.
On that basis, given that you are increasing the front braking ability by quite a reasonable amount, then yes, putting at least the 330mm kit on the rear would probably be a good idea. If you were to look on D2's site, you would see that they do mildly recommend that you match upgrades at both ends.
Do not consider the Vspec rears to be an upgrade that you would notice the effect of. The changes are really too small, and they were intended to work with 324mm front rotors. Hence why I suggested you would go for at least the D2 330 rear equivalents if you were to do anything.
If you are just aiming for your club level track day
Front Upgrade
Stock rear
Stock Master Cylinder
It's what most people do, and it works fine.
Rear upgrade isn't required unless you need more heat dissipation capacity from the larger rotor etc - only needed in a totally dedicated track car that's aiming for LOT of laps and 15mins+ running time (which is well over & above your club level sprint days).
You're doing it wrong. Very very wrong. You have to square the diameters to compare them. Area is not the same as sum of diameters.
Area = pi*(d^2)/4
4 x 40.44mm pistons has total area = 5127.582mm2.
4 x 26.4 + 4x 31 mm pistons has total area = 2189.564 + 3019.071 = 5208.635 mm2 which is 1.5% more than the original calipers.
ahh that's what I was about to say :) D2 piston area is almost identical to standard although the disc and caliper is much larger. So they are a great swap with no impact on front/rear bias :)
I wouldn't bother changing the rears in any case, you just change the pads to be more or less aggressive if you want to change the front/rear balance a little. No need to change the caliper and disc they are already adequately large in almost all use
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
