8Pot + 356Mm Front Brakes/ Rear Brake Upgrade Needed? R32Gtr
You cut that screenshot a little short; immediately below it First number is torque in Nm, then in brackets kg-m followed by ft-lb I'm not sure why they provide a range, I have always aimed for about 80% of the top to leave a little room for error
By drifter17a · Posted
I downloaded the gtr r32 manual which I understand will be pretty much same as r34 i rear the page in screenshot and if I understand correctly, the torque for the 4 bolts are 78-98 nm. Why a range? what does number below it mean( 8-10 ,52-78)? -
I doubt you'll find someone with specific experience. Any competent mechanic can service it, the motor is same as late 350z.
By weikleenget · Posted
I saw the s15 version but will it be enough force for my clutch? I guess just repairing the booster is the best option -
recently picked up a very clean example of an NA r34 and want to start dropping in some turbo parts I've got laying around. Wondering if anyone on here has chucked in a complete GTT Diff - is it straight drop in or will I have headaches? Looking to upgrade to the nismo 1.5way - but I would prefer to use the complete turbo rear end if I'm able. Also. I have a complete manual conversion here waiting to drop in, but I need to confirm which clutch bearing carrier I need, Brand new R34 Gtt gearbox with push type conversion. Any solid advice would be greatly appreciated.
