Hey I definitely don't want to kill Chris's sale, but that is the harsh reality of modified cars. But you also have to consider that for $6,500 you are only paying for the engine and associated gear, gearbox and mods - it is a bargain.
It's a paperweight (to me in my personal situation) if I can't register it, I don't have the funds to buy a tow car and all the associated stuff for a track car. Nor do I have the space, time and money to buy a shell and transfer everything into it.
a laugh at 2.5k.... no way 2.5k for a 260rwkw line with the parts I have... just the manifold, 3.5 dump and external waste gate cost over 2.5k... what about the engine management and boost control thats another thousand then you have the rims the suspension and the rest of the exhaust theres another 2.5 to 3k. And then you have a dogbox. Huge oil cooler the size of a radiator and cooler The blow off valves-two of - now thats prob more than 6.5k just there..... and then you have the car and motor.... heheheheee what a laugh.... it says 6.5k firm - thats firm with defect,
The oil leak was just the oil spurting out of the oil dipstick when not inserted correctly and giving it a bit while still cold.... which i hardly ever did... hence all sorted.....
Agreed nightcrawler.... I would be perfectly honest to say I would be sad to part with it for that price..... I have just ordered new rear tyres too.....
It will drive back fine to qld.... I still need to buy the 20 dollar turbo gasket (being purchased tomorrow tomorrow and fit)..... that can be a pain to get the turbo off the exhaust manifold because of the amount of room under the exhaust turbine and the room between the manifold bolts and the engine....you can not get a socket and wrench in there..... I have found a shortened O spanner however made of high tensile steel in order to do it although it will still be no walk in the park.... just cracking them is the hard part once they are loosened it is easy.... :-)
buy it ---> drive it back --> de rego --> engineer --> re-rego --> skids + pics!
  • 1 month later...
MMmm would be an option but i do not have the stock parts turbo low mount manifold etc i only have the gduounk parts.... i am not too sure how much the box was... I will try and find out...
$so i take it this thread must be being kept hidden either that or people would not be looking for skylines with all of the goodies for such a price.......????
You can not really ever buy a modded car for with these mods for less than $12 thousand with that sort of power.......
Interesting that it has not had any interest / or sold or people look even look into it further....
strip, sell, make more than $6k :)
or strip, sell, buy stock parts, sell car, make more than $6k
just requires effort and a few slabs of beer with your mates
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
