Interior is rather close to mint condition apart from some very slight plastic peel due to some sort of harsh cleaning liquid being used at one point of time just under the clock.....
I'm still interested mate, but I need to know more about this box, could be an expensive ppg or osgiken, or jus some worthless junk that will blow up first time it sees 300rwkw.
Very keen but only with info on the box.
I'm a bit in the dark regarding defects and legalities, but I have an N/A R33 which i'm currently deciding what to do with.. (service & keep or buy another car). Would this car for sale be of any use to me in the sense of swapping out all the parts into mine or vice versa? I mean legally is there anything worthwhile I could actually do with both cars? Can a non-defected non-turbo be upgraded using this car with less hassle than getting the defect removed on it?
Edited by Infraction
mmmmm you could but i would not waste my time....... You would have to swap the engine management, wiring harness, and a lot of other waste of time head hassle bits plus you would want to swap the brakes aswell (just sell your NA and buy a turbo alreaddy done up ... by far the cheapest way unless oyu have the right tools, garage, and know what you are doing... Y
ou could prob do it but i would not waste my time: not that i mean to kill my sale LOL
You can organise a time to come around and have a look i should be back by sun / mon at the latest (currently in victoria laying low from the people that try and dispose of people unlawfully that are from acers and police etc)...... snaps quickly into gear with a pop too.....
is that jimmy sway?
Your stock gear box from a 33 should be able to handle easily 300rwkw....... if you crank it into gear you might start getting a little bit clunky.... You are much more likely to go through your clutch than your gear box!!! I have seen people running well over 300 rwkw from the stock 33 five speed.....
MMmm would be an option but i do not have the stock parts turbo low mount manifold etc i only have the gduounk parts.... i am not too sure how much the box was... I will try and find out...
I got a complete stock setup that will be perfect for this car :D
How is that stealthy bump? He updated the thread to say he'd replied to the PM I sent him.
Same thing almost every other seller does?
Thanks for the reply by the way, pm me/update this thread when you have the info.
Cheers
Cheers
Not a prob will do: can not beleive that this car for this price has not even sold for some ones thrash car.....
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
