Hey guys up for sale is my 92 model r32 GTR currently neededing a new engine has everything else cooler gearbox etc
140,000 thousand ks on chassis
slotted discks
r33 gtr gearbox
nismo front and rear diffs
excedy clutch
leather interior/carbon trims
tomie cluster
good stero
can include power fc and boost controller depending on price
stock front mount
bilstein suspension
nismo bushes
momo wheel
alpha horn
car has great suspenison mods and very strong driveline, you can pick up a good rb26 these days well priced or this maybe perfect for someone who alreay has a motor
car has a small amount of rust near back window but thats all otherwise paint condition is good for a old car
car is located in melbourne and currently has tassie rego
(car was bought over)
after 8k
contact sam 0401938623
thanks for viewing
Edited by On p's
https://www.sau.com.au/forums/topic/419029-r32-gtr-needs-engine/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
