Hi guys. Im wanting to swap the diff insert/pumpkin with matching 4.1 crown and pinion from an r33 into an r32 diff housing. My current diff has done a few k's and is getting a but tired and rumbly. I have done the usual google searching so know about different sized crown wheel bolts etc but haven't managed to get a straight answer. The r33 diff is not abs whereas my r32 one is. It will be sent off to the diff guy to get setup properly but don't want to dick around machining bits just wondering if it's an easy swap over, particularly with the pinion.
It would be nice to hear from someone who knows and has either done or tried the swap.
https://www.sau.com.au/forums/topic/419036-r32r33-diff-compatibility/
Same same. I have S15 centre with R34 CW&P on it in R32 housing. I needed different stub axles because of the helical centre, but if you're swapping from R32 viscous to R33 viscous your stub axles will fit. You will almost certainly need new seals, and it will certainly need to be set up by a diff specialist to make it right.
But......I cannot imagine why anyone would spend the money to a) buy another viscous diff with the intention of using the centre, b) actually then pay someone to install it into a housing, and c) use it. You should get a mechanical LSD, or a helical, and put that in instead. VLSDs are useless. The R33s are not much younger than the R32s now and are therefore equally rooted.
Do not do it.
All i am really concerned about is if the non abs R33 pinion will go into the R32 abs housing. I have heard of different pinion lengths and bearing types.
The diff is out of a mates car and only has 60,000 ks on it so its pretty tidy.
The car is mostly street driven and i just need a decent diff that doesnt rattle and viabrate.
viscous diffs arent that bad as long as you dont expect too much fron them or drive like a complete monkey.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
