  • Replies 192
You can have straight legs, or bent legs, or any position you like...you just can't move them out of this position while doing it / use them to kip. It other words, lift only with your arms.
I like this challenge... will post up vid on monday. Did someone say no straight legs?
There is a list of rules at the start. complete hang at the bottom of the rep, arm completely straight. That is the most common thing people don't normally do.
A new challenger appears
http://www.youtube.com/watch?v=OKhk_e7zjpo
Third attempt
http://www.youtube.com/watch?v=VhpUfQ25F_U
Think I have more in me, so will attempt again when fresh. I did these after rows, which I reckon taxed me a bit. Hopefully the form is acceptable, judge rev!
Thanks dudes...
Bet rev is waiting for Feb 28 to post a video of him clocking 30 :P
Nah back in the day (in my 20's) I could do 50 and 20 muscle ups (I haven't even tried doing one muscle ups in a decade). .
Challenge wise, I have a left arm injury that will take some time to recoup. I was thinking someone else, younger than me could win this one. I'll try and post a vid a week of me having a go all the same to keep it in the spirit.
Maybe another thread for those trying to hit 20 pullups. It's a good goal.
Edited by rev210
Lets have the lead change daily here because waiting till the end of the month to present is boring. This isn't about being insecure, putting up your best effort will get encouragement. For those who are trying to win, bring along everyone to be inspired by posting progress vids.
In that spirit , here's a 14 rep one with my trusty 30kg backpack.
Not my back day but, I want to encourage the competition. Lets get to 15. And if you can't do 10 don't leave it, make Feb the month to make it a first.
http://www.youtube.com/watch?v=kbqP1W1OkEs
Edited by rev210
lol fk ya rev...now I gotta do 15 next week. May have to instigate a rule that you can't win two challenges in a row, so I have a chance at winning one :P
Agree about the vids...let's get some more up already. You can always post multiple attempts until the end of the month. No f**ks given if you can only muster 1, this shit ain't easy.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
