macdog Posted February 10, 2013 Share Posted February 10, 2013 (edited) second attempt coming...... Edited February 10, 2013 by macdog Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6745012 Share on other sites More sharing options...
rev210 Posted February 10, 2013 Author Share Posted February 10, 2013 good job! however for the comp, you had just a little too much resting hang time on that first attempt at the bottom of the reps. As per the rule. * No resting at the bottom of the rep, Your first 2 reps are right in that first video set for form, are what you are after. All the way to the bottom/straight arm stretch. then straight back up ,no hang time. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6745177 Share on other sites More sharing options...
macdog Posted February 10, 2013 Share Posted February 10, 2013 fck man... it's sooo hard!!! Second attempt has more rest.. haha, will post up another attempt later. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6745208 Share on other sites More sharing options...
rev210 Posted February 10, 2013 Author Share Posted February 10, 2013 no good job regardless. Yes it is harder without the rest but, it's a great effort anyway. Keep going mate! Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6745217 Share on other sites More sharing options...
macdog Posted February 11, 2013 Share Posted February 11, 2013 thanks, second attempt... Third attempt will have no stops... Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746100 Share on other sites More sharing options...
NickR33 Posted February 11, 2013 Share Posted February 11, 2013 good work! I have no problem with the pauses, not sure what the big deal is... I reckon its harder when you rest, you lose all tension and have to complete the rep from a dead hang Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746196 Share on other sites More sharing options...
Birds Posted February 11, 2013 Share Posted February 11, 2013 I agree to an extent (pun)...however...if pausing makes it harder, why wouldn't you just keep going to get more reps out? Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746250 Share on other sites More sharing options...
TTT Posted February 11, 2013 Share Posted February 11, 2013 I find I start to swing a little if I don't pause down the bottom every few reps. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746319 Share on other sites More sharing options...
Birds Posted February 11, 2013 Share Posted February 11, 2013 Pulling slower / more controlled and less explosively reduces the swing a bit, but then you do lose reps. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746356 Share on other sites More sharing options...
TTT Posted February 11, 2013 Share Posted February 11, 2013 going slow is for wimps.. I like to go fast and finish quick in everything I do Then sleep. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746388 Share on other sites More sharing options...
Birds Posted February 11, 2013 Share Posted February 11, 2013 And he doesn't complain about that? Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746400 Share on other sites More sharing options...
markos Posted February 11, 2013 Share Posted February 11, 2013 Resting is way harder, if you want proof, make everyone rest for a count of five at the bottom, see how they go then Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746427 Share on other sites More sharing options...
Mitcho_7 Posted February 11, 2013 Share Posted February 11, 2013 Agreed, it's like bouncing deadlifts when doing them for reps. You use the elasticity that is stored in the muscle when you don't pause, whereas with the pause you have to generate all the force. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746474 Share on other sites More sharing options...
rev210 Posted February 11, 2013 Author Share Posted February 11, 2013 Resting is way harder, if you want proof, make everyone rest for a count of five at the bottom, see how they go then From experience it's actually easier to rest in a hang between reps. As macdog appreciates from his recent experience, a little rest is helpful , There is an opportunity for relaxation of some of the key back muscles at the bottom of the rep. I can hang for quite some time, almost to the point where I can rest between sets. The muscle fatigue is different, it is mostly your grip and arms. This is a back movement chiefly the way it prescribed. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746623 Share on other sites More sharing options...
rev210 Posted February 11, 2013 Author Share Posted February 11, 2013 Agreed, it's like bouncing deadlifts when doing them for reps. You use the elasticity that is stored in the muscle when you don't pause, whereas with the pause you have to generate all the force. No. You will find done right you are lowering just past the point where the dynamic tension affords much advantage. This 'bouncing' is also noted as 'not allowed' in the rules. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746631 Share on other sites More sharing options...
rev210 Posted February 11, 2013 Author Share Posted February 11, 2013 I have no problem if someone believes the rules makes the pullup 'easier'. This belief alone might help you do more. However, as the rule stands. Pauses are out. If you don't need to pause , don't do it. Then we can count the effort. Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746632 Share on other sites More sharing options...
TTT Posted February 11, 2013 Share Posted February 11, 2013 (edited) And he doesn't complain about that? Of course he she does. But I'm asleep remember.. edit.. she.. SHE!!! Edited February 11, 2013 by TTT Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746716 Share on other sites More sharing options...
Birds Posted February 11, 2013 Share Posted February 11, 2013 I have no problem if someone believes the rules makes the pullup 'easier'. This belief alone might help you do more. However, as the rule stands. Pauses are out. If you don't need to pause , don't do it. Then we can count the effort. +1 If the rule benefits you, then why complain about it??? It's not that hard to stick to it. Get some more vids up people...the weekend is over now! Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6746738 Share on other sites More sharing options...
macdog Posted February 11, 2013 Share Posted February 11, 2013 I have no problem if someone believes the rules makes the pullup 'easier'. This belief alone might help you do more. However, as the rule stands. Pauses are out. If you don't need to pause , don't do it. Then we can count the effort. Plus... I think doing chin ups first thing in the morning is better. Punched out 15 this morning at 6:30am no rest. dont have a video though. will take one thursday morning!! haha Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6747237 Share on other sites More sharing options...
macdog Posted February 12, 2013 Share Posted February 12, 2013 third attempt... Link to comment https://www.sau.com.au/forums/topic/419064-pullup-challenge/page/5/#findComment-6748143 Share on other sites More sharing options...
