  • Replies 192
Yep, thats why a paused bench is easier, resting with a dead stop on the chest makes the press so much easier lol
To eradicate attempts like the one just posted, simply make everyone pause in a dead hang, so much easier to judge as well
third attempt...
I don't mean to be a pill...but no kipping and straighten those arms! If you put your legs behind you like rev and I did, you will find it easier to avoid naturally kipping in the last reps. I actually preferred your earlier attempts to this one haha sorry :P
Shouldn't complain, at least you're posting vids!
Where are the rest...come on Joey, Trozzle, Husky...
I'm only just recovering from a mean throat infection, so I honestly just don't give a shit to do this just yet lol
Also I'm in a "kill every flamin mongrel that isn't actually lifting" mood right now after walking into my gym, getting changed, discovering that almost EVERY single piece of equipment was being "used" (read: f**kheads occupying it while not actually doing anything productive), and subsequently leaving because I have better things to do with my time than wait around for these stupid pricks. I'll go later...when the f**kwads have left.
Yeah, hahaha.
Earlier attempts were probably better...
I wanted to get past 15 reps Birds!!
As you said tuck your legs behind you... I find that position really hurts my back.
Also, yeah.... where are all the other attempts from people!! FKC!! haha
Very. dream boats like them are pretty much the reason I'm left with ~45 mins every evening to relax before I gotta be in bed...
don't you wish sometimes you could just punch people in the face and it would be okay.
Looks like everyone waits till the last day, maybe a month is too long, a week may be better, everyone trains each lift at least once a week, film it.
Six pages, over 100 posts, how many vids, still 16 days to go
You might be right about the pattern , the deadlift challenge was the same sort of average posts and vids.
I suspect that even if it was a week the same people will still do it. maybe over a month those same people can increase the attempts to better ones.
Knees tucked behind you is slightly harder , it changes the angle of force and recruits the core slightly more to stabilize. It shouldn't hurt your back mate, that might be something to look at. The pain could be just muscle soreness and possibly a good thing for you. If not then it's would be worth getting that checked out.
Just stick to whatever is most comfortable for you in this challenge.
I do see your point because you could argue that like the bottom of the bench rep, grip muscles are part of stabilizing. But , as this challenge is geared to testing the back , the stretched point of the hang involves your grip fatigue. It does allow the back muscles a rest. Lets just say if you train for hanging off the bar you can build up quite a decent amount of endurance in your grip. In fact that is another exercise. Weighted hangs for time and Static holds, where you hold a partial rep with a load you can't fully rep. I would be doing these now save for the injury.
I just did some more weighted pullups and managed 1 more this way, with a 3-5 second pause. My grip gave out before my back, mostly from pain in my left arm (I may have higher grip endurance than others however). Doing it the challenge way I find the back is failing on the last rep not my grip.
Here's a video of my effort. I'll let you decide on how many I actually 'completed'...
Weight: 80kg
Height: 5ft 7"
http://s115.beta.photobucket.com/user/SRS13JH/media/IMG_0364_zpsa3a90d20.mp4.html
Edited by SRS13
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
