20+ is going to be required to win this is my guess. Although the highest number isn't at that point yet.
Be great to see a few people hit 10's / 15's and even 20+
Maybe Markos can post up a vid of one of the PTC boys or gals showing us how 20+ is done for inspiration?
  • Replies 192
At the moment I'm not taking these but, I reckon creatine + beta alanine supplimentation if you aren't on it would likely give you a few more reps ha ha...
Best way is to train the movement a couple of times a week instead of one. With a focus on adding one rep.
20 is a high number for anyone. So even getting close is an achievement.
Anything north of 15 is great.
next challenge should be this.
20 minutes of the following:
5 x Chin ups
10 x push ups
10 x squats.
Tell me how many sets you get.
No breaks.
This sounds like one of my work training sessions, only thing missing is 20 meter sprints between exersizes, and doing it for 40 minutes.
I usually break at least 1 lung and sprain my heart muscle doing it though, vomiting is always a option as well.
I managed 15 good heaves, no selfies though so no count, Joey, hit me up next time your at the school, weight session then beers.
that's what I'm talking about.
Good work... with 20 meter sprints... definitely would need another set of lungs.
This is what I mean when I say you can use the dead hang for a rest (and why it's banned)
For the powerlifting types how about a go at the world record of weighted pullups. 94kg
Pretty strong guy still... fck.
good effort 10 4 . No you get 10 points for posting the video of your efforts.
However, you need to reach full stretch at the bottom of the rep (arms straight) for your effort to count in the comp. The rest of your form is spot on.
It does make it much harder going right to the full stretch point but, it also increases your full ROM strength as a bonus. Might initially do less but, you will get stronger the more you attempt.
Edited by rev210
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
