  • Replies 192
Jeppe, are you training to be able to do them?
I know that nearly all the girls that start at my gym really, really want to be able to do them.
We have quite a few girls who can do wide grip dead hang chins here, we have a pretty good program for getting it done.
Nina couldnt even put a bend in her arm when she started, has done 16 now
Three other girls do over 5 perfect reps as well, quite a few can do at least 1
Good luck with it
it should be..
there are squats, and strong backs..
everything else is just a reflection in an illegally dark window tint.
Wait til you see my line of polished motorbike fender reflections from the winter catalogue...check out that muscle bending convex
Hey Charlie Jeppe, off topic, one of my clients just saw me posting on here, he noticed your pic and he told me your spastically quick around the island.on your bike.
He did a track day with you a year ago, he also said you were hot.
No not weighted. I just did a vid of my workout. So we can kick start. 8 reps is easy to beat. You just need a vid.
There doesn't need to be a pause, just your arm fully extended/straight at the bottom. No real hang time just full ROM.
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
