  • Replies 192
good job!
however for the comp, you had just a little too much resting hang time on that first attempt at the bottom of the reps. As per the rule.
* No resting at the bottom of the rep,
Your first 2 reps are right in that first video set for form, are what you are after. All the way to the bottom/straight arm stretch. then straight back up ,no hang time.
Resting is way harder, if you want proof, make everyone rest for a count of five at the bottom, see how they go then
From experience it's actually easier to rest in a hang between reps.
As macdog appreciates from his recent experience, a little rest is helpful , There is an opportunity for relaxation of some of the key back muscles at the bottom of the rep.
I can hang for quite some time, almost to the point where I can rest between sets. The muscle fatigue is different, it is mostly your grip and arms. This is a back movement chiefly the way it prescribed.
Agreed, it's like bouncing deadlifts when doing them for reps. You use the elasticity that is stored in the muscle when you don't pause, whereas with the pause you have to generate all the force.
No. You will find done right you are lowering just past the point where the dynamic tension affords much advantage. This 'bouncing' is also noted as 'not allowed' in the rules.
I have no problem if someone believes the rules makes the pullup 'easier'. This belief alone might help you do more.
However, as the rule stands. Pauses are out. If you don't need to pause , don't do it. Then we can count the effort.
+1
If the rule benefits you, then why complain about it??? It's not that hard to stick to it. Get some more vids up people...the weekend is over now!
Plus...
I think doing chin ups first thing in the morning is better.
Punched out 15 this morning at 6:30am no rest. dont have a video though. will take one thursday morning!! haha
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
