  • Replies 192
exactly the same as mine.
PS - while doing cuban press to fix my right shoulder, I've hurt my left one.
The failure is strong.
Funny you say this, cause my left shoulder is also injured (though I can tell it's just muscular and temporary), most likely from taking up any slack of my right shoulder during exercise
Turning into you...must be all these squats I'm doing.
It didn't hurt during pullups or pulldown, only after the gym during resting state (not a terrible pain either, just one of thiose annoying twinges that hangs about), which made it difficult to diagnose what exercise was responsible. I took a week off gym to give it some recovery time and that seemed to do good for it, because I have no pain after a workout now...shoulder still clicks/creaks a bit with certain movements though.
If it helps with diagnosis, I tried the Cuban press exercise you two recommended and during the rotation movement (after the upright row) is where the shoulder ratchets/cracks. It used to hurt a tad doing this, but now it just cracks.
Re: boxing, I definitely had some sort of injury from it...woke up after a heavy bag session with what I thought was a small muscle tear (felt like it was in the bicep), which I ignored, but I'm fairly certain it has evolved into this. Probably the farking hook punches.
the problem with the rotator is that the pain is 'reffered' . Sometimes you won't feel the damage being/done at all. The inflamation has the result of reducing the ROM that might otherwise cause some pain. You get hurt more when weights reach a point of forcing a 'dynamic stretch' beyond that restricted ROM. You can do a few things to check it. If you have this reduction in ROM , treat it as serious as if you have screaming pain and do the rehab to restore it to normal first. No pressing at all. May get fixed in as little as a few days.
  • Forward elevation. The motion involved in
    reaching forward and up to a cupboard above the head. This is measured
    from zero (lowest) to 180 degrees. . Do you rotate your rib cage to get to this position? If yes then you need some scapular ROM improvement too.
  • Internal rotation. rotate
    arm across back and walk the fingers as far up the back as
    possible, Even try reaching over your back with the other arm. See if you can touch hands. If you have issues this may only be a sacral level on your back (if you can't get closer than the width of your hand then you suck at it). Compare the internal rotation of the injured side with the normal side.
  • External rotation. keep
    the upper arms flat against sides and rotate the forearms
    outward. The range is from zero (straight ahead) to 90 degrees.
  • The lift-off test. This tests the subscapularis. With the arm behind the back, make a fist with thumb pointing backwards, lift his hand off your back.
Appart from restricted ROM, that clicking (even on Cubans) you need to get motor control back into that shoulder. the muscles need to re-learn the sequence. I mentioned it before around the feedback. If you get no clicking doing the movement without a bar or weights then stick to that and go to fatigue and gradually train up in load.
Edited by rev210
I think these might be too slow..
Perhaps we should just set out a bunch of challenges that anyone can attempt at any time as part of their gym session.
squats for reps
bench for reps
deads (already done)
pullups
OH press
Tabata thrusters for the cardio kings
100m sprint?
rowing?
edit - create a thread for each and people can update each when they attempt it... only video entries count.
if you did 25 reps of OH press but didn't video it, then don't post.
thoughts?
Edited by TTT
Dunno, I like the way we've been doing it...I just think people are scared of pullups. Willing to bet bench will be much more popular.
Deadlifts got a good response, maybe because it was novelty but guess we'll see.
A week is too long
A month is absurd
Really? I don't think it's the time frame being too long, so much as there are only going to be a certain number of people participating. I think less people will participate ,with less than a week.
I quite liked the deadlift one going for a month, I don't think I would have put in the effort to improve otherwise.
I think the buy in for something like bench press is going to be more popular.
TTT's idea is good except I think each one should start from the rolling challenges we are doing. We have a deadlift 1.5x and a dead hang pullup. Could have a thread for each now. As winners pick new ones then they become a place for people to post progress? For the Competitive crowd maybe a leaderboard can be in there.
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
