Hi guys have the following parts up for sale been laying around the garage for too long gotta make some room
Parts located in Sydney rouse hill area
Local pickup only at this stage currently in a leg cast so bit hard for me to get around ATM
Most parts of my 1998 R34 Gtt
Stock front bar minor marks on bar due to laying around garage and little bit of bottom grill cut away to make room for front mount
$100
Stock centre gauge cluster just the gauges no holder working order
$100
Nismo shocks and springs damper adjustable perfect working order and condition taken of car at 55000klms
$600
Stock ecu with nistune chip making 220 kw/aw chipped at 60000km only had it on car for 5000kms
No casing
$500
Stock injectors 65000km old
$100
Stock coil packs 65000km old
$50
Stock fuel pump no filter bag 65000km old
$50
Xenon complete driver side head light broken mount clips lens needs a light buff on top
$300
Stock intercooler 55000 km old just cooler no pipes etc
$100
Stock op6 turbo blown would suit hi flow rebuild
$100
Stock turbo back full exhaust 55000km old with gutted stock cat most heat shields are there (just have to check)
$200
Stock yellow fender indicators
$10
Stock yellow bumbler indicators
$20
Stock disc brakes removed at 65000km would suit machining
$100
Stock afm
$50
New in box irridium plugs part no:BCPR6EIX-11
$30
Stock air box with snorkel removed at 50000km
$50
Stock BOV removed at 50000km
$50
Some other random car stuff
2011 Mazda bt50 passenger side head light scratch down head light lens
$50
Bt50 bumper standard black bar scratch down passenger side
$50
Tow bar hitch without ball
$20
Sony head unit roughly bout 7 yrs old still perfect working order been in my last 2 cars never missed a beat cd &tuner
$30
Most prices are negotiable
Can't get picks up atm (won't let me for some reason) please contact on my mobile for pics and fast reply (don't check this forum daily) 0419575458
Cheers Jason
Ill take the spark plugs if its the whole set of 6 for $30.
Yes there are a total of 6 brand new in box contact me with number above to organise pick up
Cheers
Jason
what was the nistune tuned for?
Nistune made 220aw/kw with the following mods
Full 3" exhaust w/hi flow cat
Front mount inter cooler
Electronic boost controller 14 psi
Pod filter
Stock internals
Stock fuel supply (pump injectors etc)
Stock turbo
All works on nistune done by Mark @ MRC castle hill
Please SMS no in original post for pic of board chip with serial no's etc
Hope this helps :)
Cheers
hey mate thanks for the pics last night. am wondering: are your nismo shocks bilstein branded or just nismo branded (if you know)?
i know they have nismo on them but are they made by bilstein etc as i've read in other places that this was an option?
Edited by darksky34
Hi darksky34
Not too sure I can have a close look at them when I get home will reply asap
Cheers
Hi darksky34
Cheers
Sorry for delayed reply
Upon closer inspection there are no labels badging etc that say bilstein there is a whole lot of jap writing and nismo stamped at base of shock pm me ur mobile and I can send pics of stamping
Hope this helps :)
Cheers
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
