Hey guys got a bit of stuff I want to clear out
Make an offer on anything pick up in Narre warren
I am happy to assist in posting small items
Text or call for pictures as I am only on the phone
0437684980
1st... I have rb20 red top covers no valley cover $200 Ono
2nd... a set of brand new d-max Japan alloy cradle bushes to suit all Nissan IRS cradles r32 s13 etc $80 Ono
3rd.. rb30 engine runs well was reconditioned 2years ago and hasn't been used for long comes with manual ecu and MAF , has no exhaust manifold or alternater
Asking $350 Ono
4th... I have an rb26 engine in parts! It's mostly all there
Has no cams, injectors coilpacks , water pump.
Has a modified gtr sump for rear wheel drive crank needs machining
Head is good $1500 Ono Pics on request
5th... R32gtst gearbox ok condition, has no gear stick clutch fork
Reverse switch or speedo drive 2nd gear grinds a bit
$150 Ono
6th.. R32 rb26 ecu stock! $100 Ono
7th.. Near new set of rb26 conversion mounts to suit s13-s14-s15 made by full race USA
Has nismo engine mounts and trans mount
Xs power engine pipe and dumps these have been moded to fit in an s-series car
Pics on request...$400 Ono
Please call or text for more info and pictures
0437684980 thanks
https://www.sau.com.au/forums/topic/419087-rb26-parts-engine-and-misc-stuff/
  • 2 months later...
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
