Alright guys, I tried searching couldn't find an answer for what I was looking for.
I'm going to run an external gate on my r33, I'm wondering if swapping between plumbing back and running screamer will it affect the tune?
I'd run screamer usually but if I run into trouble with the popo I obviously would have to plumb in.
Everything would be v band to make life easy between swapping a plumb pipe in or swapping to a screamer with a blank on the dump.
Would swapping between the two affect the way the car drives?
Merge the two a decent length down the exhaust and make the merge angle blunt as possible. It shouldn't effect the tune a great deal if the merge is okay.
I know there is guys who have back to backed with external gates and reckon they gain hp venting to atmosphere. I'd like to see how the merge was done in those examples
I didn't notice any difference plumbing mine back in at the cat..
.except the car is a shit load quieter and more enjoyable to drive now...screamers get boring real quik n a street car and the disadvantages far outweigh the benefits
I say yes as back pressure will increase with the plumb back......How much of a difference??? I dont know
If back pressure increases in the exhaust its due to the merge of the two gases not being correct. Not because the waste gate is plumbed back
If you plumb the waste gate in, you're pushing more gas down the exhaust, so it will always increase back pressure, even if the merge is perfect. If the exhaust is properly sized the increase will be negligible. If its too small, it will be significant.
The ammount of exhaust gas being bypassed on boost is not that great compared to the ammount required to drive the turbine.
Years ago I did a back to back on my race car with internal GTRS turbos and then the same turbos with external gates/screamers and welded up internal flaps. Made no power differnece but boost control was more steady over a long period (say ec main straight and Bathurst)
We ran it on the dyno twice and the tune was the same. All the lambda logging was the same too. Only differnece was the boost was a steady 28psi instead of a slight wave from 28-30psi.
A waste gate merged at 90deg to the main pipe or even 45deg to the main pipe is not much good but is the normal easiest way to do it.
You won't notice squat difference driving it around on the road if the merge is good.
Mine merges into the front of the cat body. So a 3inch front pipe and 2 inch screamer enter a 5inch body cat seperatly then exit into 3.5 inch exhaust...sound is sex on boost too... :)
The thing to look at is surface area not diameter.
Your 3in exhaust is 7.06in
Your 2in screamer is 3.14in
Total surface area of 10.20in
A 3.5 system has a surface of 9.62in
I can't see that being a problem as a 2inch screamer pipe is way overkill and you wouldn't be anywhere near its capacity.
Most 1.5in gates are adequate
So 3inch at 7.06in
1.5 screamer at 1.76
Total of 8.82in surface area
A 3 inch exhaust would Sufice and not be a restriction at most people's level if the merge is right
We've regularly used 1.5in gates on 400-450kw engines with no problems so I highly doubt the 1.5 screamer is at capacity on most people's 300ish kw setups
A 3.5 inch exhaust (which is typically what we use for anything 400kw +) would have a greater surface area than the dump and screamer pipe. It couldn't possibly be a restriction if the merge is done right.
My math might be off having done it on an I phone calculator but it appears correct.
area of a circle app(android)ftw!
twin 3" exhaust, nearly identical to 4" single.
also consider what youll use the car for.
alot of tracks in motorsport dont allow gate.
and you may have to run 2 tunes to make the most from it.
Ask your tuner about tunes.
I remember talking once to dvs jez, and he didn't sound confident on tuning a screamer for 95octane.
if it didn't make a difference, it wouldnt matter.
I run mine both ways, no problem.... :)
The Haltech would adjust for it no problem man.
How my old tuner explained it anyway, I asked if it could be done and he said with the Nistune it's a bit difficult but with something like the Link it would be easy.
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
