Hey everyone,
I'm after some help. Im trying to check the timing on my rb20det. Am I right in saying that number 1 cylinder is the first cylinder after the inlet and exhaust cams.
I hooked my timing light up to the black loop wire at the back of the motor and my harmonic balancer degree was about 35 degree.
I want to hook it up to number one plu to check that the other reading could have been possibly doubled.
Also I have a autronic Eccu and a auto trans. What should the timing be set up to?
Can anyone help me out?
Thanks in advance
https://www.sau.com.au/forums/topic/419143-rb20det-timing/
number 1 cylinder is the front cyclinder.
the wire loop sometimes gives false readings. the most reliable way to test the timing is to get an old fashioned ignition lead and remove the coil pack from number 1 and put the ignition lead between the coil and the spark plug and hook the timing light up to that.
timing wise, i think the auto is supposed to be slightly different to the manual by a degree or 2 (it's been a long time since i looked it up). the manual is supposed to be about 15 degrees BTDC. if you are getting 35 degrees then i'm guessing that it's obviously no where near the timing marks on the crank pulley?
https://www.sau.com.au/forums/topic/419143-rb20det-timing/#findComment-6734401
Ok, didn't realise the timing marks went to 30 degrees on those.
As for introducing the lead, you just pull the coil pack out (leaving it plugged into the wiring harness), get an old ignition lead and plug it into the part of the coil that goes over the top of the spark plug, and the other end onto the spark plug. Then clip the timing light onto the lead and test the timing as normal.
Also search to find out the correct procedure for putting the car into timing mode. for example, with a r33 you warm the car up, turn it off, unplug the tps and then start the car again. This is supposed to lock the timing at 15 degrees (it will normally fluctuate a small amount). Also make sure the car is warm when checking the timing, even if not locking into timing mode.
https://www.sau.com.au/forums/topic/419143-rb20det-timing/#findComment-6734524
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
