M35 Boot Latch Motor Replacement Help
ClassOne
 Share
Can anyone give me tips on how to get access to the boot latch motor?
My boot intemitantly doesn't work, I've replaced the control module , and no change.
It's either the button or the micro switch on the motor .
But the plastic under the interior cover is moulded 1 piece and the gas strut and hinges all bolt through that plastic.
Tries to pop off the lower tail gate outer which is plastic, but I'm to the point where I'm going to break the clips that hold it in.
Anyone got any knowledge of this?
I'm pretty much out of ideas .
Taking the whole tail gate off the car to change the motor just seem really dumb, I'd expect that from KiA or Hyundai
Hey mate ive completed this and what a .... of a job it is. Ok 1st take off the inside boot carpet untill you can see motor. On bottom off boot where it latches there are 3 star screws that have to be removed. On inside off boot cover there are 3 bolts from memory that. Need to be removed aswell. Next you need to pop out the outsude boot panel a little bit as there is a support mount with 2 bolts in there. This bit is really fiddly.No you dont need to remove the whole panel. Next you will have to unclip wires and seperate the boot latch
inside the boot door to remove. To fit new replacement you will have to seperate unit into 2 and reverse the last previous steps to install. The support in lower outside boot panel i didnt bother re installing as it was too anoying. Hope this helps. Its a anoying and fiddly job but well worth the effort . I hated opening boot via inside latch before i did this.
Edited by joshm35
Thanks josh, sounds like a royal biatch!
If I can remove the lower boot panel in the outside I'd have clean access, I've take off the clips on the trailing edge so I can see under it a little, but I just don't want to break all the clips that hold the rest if that panel in.
You have that same problem?
Sorry about my bad spelling above, kinda paint a bad picture.. was on my phone as well.
Ive got another motor and module here, changed the module and the issue is still there, now for the motor, if its not the motor then its the button... please dont be the button!!!
ill attempt to pop the lower outer panel off.. i swear i was going to break it yesterday ...
Thanks for the tips guys.. will let you know how i go.
So I got the job done,
Got the latch mech out in one piece , I took some pics of the process to show how it's done, because if you don't know it's a real pain doing it.
Will post them up with a brief description so the next guy can have it done in under 1 hr.
Good onya Max. Post it up on m35stagea.info as well. That's where all the good info resides.
  • 5 months later...
Any pics of how to. My boot won´t open at all. Not sure whats wrong with it. I can open it using the manual release on the inside but using the outside button nothing happens.
Any ideas whats wrong?
Damn it, first this then my bike wont start and had to leave it at the servo. This just isnt my week.
Hopefully Classone still has his how to on it.
Now off to look for a new motor and get my bike before it gets pinched.
I'll see if I can dig up the pics.
I'll try explain the main things.
1st remove the inner tail gate. (Carpeted lower section)
And the plastic outer, your gonna need a flat blade to lever it.. I thought I was going to break it.
It's stubborn!
Peal back the plastic so you can look inside.
Take the (4 or 6) bolts out of the boot latch/mech
It's all one piece.
Un clip the wiring, and I think I moved the control box which is on the left hand side (viewed looking at the latch)
The motor/mech assembly is a bitch to remove..
It's so tight!
I dropped in down into the cavity and moved it to the right of its mount bracket.
It pretty much has to do a complete 360 to remove it and you remove it from the left of where it was bolted in..
So it drops down moves to the right, goes around the mount bracket while starting the 360' turn and exits a hole to the left of its original mount position.
The pain is the latch! It's size!
Once it's out and moved to the right, push the thinner section (with the motor) up as far as you can get it into the tight cavity (towards the glass).
Then rotate it clockwise while trying to get the fat latch past it's mounting points..
I can't stress how tight this is, you don't need physical force, it's like there is only 1 way it works, period!
After you get the latch past the mount bracket,
Keep rotating until you get the latch pointing towards the glass,
If you look now into the boot from the left side of the latch mount, you can see another cavity,
Push the fat latch up into it,
You then should be able to rotate it clockwise while pulling it down and to the left to complete its 360' rotation and end up with the latch facing you.
You will need your flat blade again to slightly bend the plastic to get the latch thru the cutout and out it comes,
Do the opposite to get it back in.
That gives you an idea.
I'll try and find the pics I took.
Don't have the stagea anymore, took on 2 kangaroos... Write off!
 Share
    • we can only guess exactly what happened from our keyboards, but to me it looks like they were targeting 27 but the wastegate was too small or poorly controlled and the boost crept up, that is quite common
    • Good points!  Took those for granted - though I *did* actually give an example of winding boost up more than it had been before where I wasn't actually specifically looking for more peak power.  The Toyota Starlet dyno plot that I shared and mentioned showed an overlay from the previous tune it had and the one I'd redone, I left the boost targetting the same as the old tune but then after peak power I ramped boost up by a good 5psi or so over what the old tune had at the same rpm. The reason I felt comfortable with this (though the owner of the car had a "are you sure?" moment when I suggested it) is that the setup wasn't turbo limited, it was largely head sealing limited and the owner was a bit concerned as for the last few seasons he'd had issues with head lifting - sometimes not completing an event without having some headgasket issue, so he didn't want to run any more boost than it was. The reasons I was ok with raising the boost a good 5+psi MORE than that was that I left it where it was in the middle, and only increased it where VE (and therefore cylinder pressure vs psi) were dropping hard and I didn't stop the torque from dropping, just reduced the drop.  Well, there is that and the fact that the previous tuner had it overtimed by near 7degrees at peak torque - but that's another story haha.    I didn't really go into detail about that "turning it up more" thing but now you've mentioned the "not detuning", sometimes the boost *can* be turned up higher than you'd expect if the setup allows for it and you do it smartly.  I've tuned things to run 30psi on BP98 "safely" that a few years ago (or still?) people would cry that it was a stupid idea - but given they were well intercooled, low EMAP turbos and only doing that kind of boost where VE is dropping etc I was pretty confident it wasn't as cowboy as it sounded at face value and we never ended up with issues as a result of it.
    • they choose the number of psi (27) around 4200? Could it produce more at this engine speed with the same turbo?
    • one thing escapes me, if the turbo spool provides the maximum boost and we can't control anything before that, how can the boost be higher by it alone.   here around 27 psi at 4200 then up to 32 psi at 6500 rpm   how does the tuner do this
    • I'm still not sure what you are trying to acheive, but I wanted to clarify something about Lithium's response to your question...   Only within certain limits. All of the examples Lithium gave were of detuning for a particular reason. Before the engine/turbo/wastegate combination has hit full boost, you can't increase it....the wastegate is shut and the turbo is pushing as hard as it can Once the combination has hit the target (controlled) boost, you generally have full control over whether it makes more or less boost, because it is being limited/reduced from its potential. This is generally done by controlling the wastegate In the top end, with an undersized turbo, it is possible you won't get to your target boost anymore if the turbo is choking up. In this case you cannot increase boost any more without changing the setup. No change in cost compared to any decent build, other than tuning time to get the engine to make less power than it is able to at a certain point
