I have finally made the decsion to sell my Skyline as for the past 18 months it has driven a whole 1500km as i have a company car and do not need it any more. I have owned it for the last 3 years and it is basically a completly stock car with a couple of minor mods that i have done.
I will be selling it without a RWC as i just dont have time to get one sorted but i dont think it will need much to get one any way.
1995 R33 GTS25T manual Coupe in white. it is the series 1.5
has travelled 127,000km. I bought it at 107,000 and the guy had it imported in 2001 so has been in the country for a long time. He had replaced all the shockies with Munroe sports shocks as well as nolethane bushes in the front.
AT time of purchase i changed the timing belt, water pump and associated items. Also had my steering rack reconditioned due to it leaking
I have changed the oil every 5,000km and the plugs in it are only 1000km old.
Interior is fantastic. No tears in the seats, it has a full set of original skyline mats. The only issue inside is the gearboot and handbrake boot are spilt and the dash surround has a few bubbles in it. It has a aftermarket steering wheel in it. I still have original steering wheel.
It has a stereo with a i pod cord in the glovebox as well as splits in the front.
It has the original wheels on it with basically no gutter rash and good tyres about 75% Standard bodykit with only small marks around it. Pretty clean i think for a 18year old car.
Mods
HAs a 2 1/2 inch cat back exhaust whitch is pretty quiet ( i am mature age so didnt want anything too loud) I have a 2/12 mild steel front pipe that hasnt been fitted as well that will go with the car as well as the standard exhaust.
K & N panel filter in stock airbox.
12 month old new alloy radiator
It runs factory boost just bypassed the two stage to just run 7psi all the time.
I have a set of 18" rims that will go with the car as well that need tyres they used to have 245's on them.
Also has a plumb back Turbosmart BOV and window tint
Now the bad points.
Clock spring is broken so airbag light is on. Was going to replace it through Chris but just didnt get around to it
Small amount of surface rust in boot on left hand side.
Boot leaks a little in rain ( which i think most R33's do)
Brakes prob need doing, pads a little low
It has a couple of bushes in the HICAS that are split so they would probably need replacing to get a RWC
NEeds a battery as it has sat for a while ( i prob try and drive it once every 3 weeks) it needs a jump start and it is now not holding charge, I might put one in if i get the right price
IT is a sad time asi love this car but it is not fair on it just sitting around as it is a great car and someone should enjoy it.
Now price. as i said it wont have a RWC i am asking for $6000. I am located in Warner on Brisbanes northside
i am negoitable but i think that is a good price for a vehicle that is basically stock and you can modify it to suite your own style
Eith pm me here or call me on 0405 313 664
Craig
And here is a pic of the rust which as you can see is not too bad
https://www.sau.com.au/forums/topic/419156-qld-r33-gts25t-manual-coupe-1995/
