Need Help Asap
gts25tnissan
 Share
Hey all i no this has prob been covered iv tryd finding/reading but i just dont understand it
Iam looking at new wheels for my r34 gtt and have found these
18x8 +45 5x114 with 225 tyres i really have no idea what this means apart from 18inch and the tyre size
So will these fit my car nicely with out sticking out the guards or to far in.
Yer there the same size as stock. just 18s so new question
Right above my stock wheels there somthing idk what it is but i assume its something to with steering and my stock wheels are about a inch or less away from the rear gards so would that make the 18s a no go with out gard rolling i have cusco coils but i dont think my cars that low or i can get drift teks the same size as the stock gtt wheels but there gold and my cars white what use think
Links to adds http://www.gumtree.com.au/s-ad/morphett-vale-area/wheels-tyres-rims/koya-drifteks-gold-for-sale-or-swaps-/1012053457
http://www.gumtree.com.au/s-ad/highbury/wheels-tyres-rims/18-x-8-45-5x-114/1012307623
Edited by gts25tnissan
225's are damn skinny the rear will break loose easy and fronts push out on power too soon , like uturns under power without a clutch kick lol
My fronts are 245 ,rears 285 on 18's no hitting at all if your not dumped in the weeds
and your alignment is setup properly
And the offset is near stock cfr what stock was?
If you can get a few fingers between your front gaurd and tyre your prob ok unless you hit a pot hole while turning or curb driveway at full lock
if anything bend the inner lip of the guard near the top , folded it tighter just a bit so the tyre wont grab it and flog it , make sure the liner is held up properly too
Edited by Carbon 34
If the offset is higher than about +35 the wheels will more than likely hit your suspension anyway. A 9j +20 will sit nice and flush with the front of a 33 and the rear can go a little lower in offset or higher in width.
Ok last try i found some more gumtree add is http://www.gumtree.com.au/s-ad/parafield-gardens/other-parts-accessories/street-drift-race-rally-items-no-longer-needed/1013603913 was looking at starcorps and sorry krishy dont realy wana go to stock would rather save till next payday but then the missis and the hole u spend more on ya car then me lol
Sorry just ead petes post they wont fit grrr whys there no rims on gumtree when i have some money there always is when i have none
Hey all my mate wonts to race me at malla nats in november i have a r34gtt with fmic pod and 3inch turbo back. He has vt ss with 320kw at the wheels so he says. hes mods are maffle tuned port and polished head and a milled cam prob a few more i stop listening after awhile. what mods do i need to make that sort of power. I have about $1500-2000 to beat him lol.
You will need a bigger turbo, bigger injectors, ecu, fuel pump, z32 afm just to get to around 300rwkw. Funnily enough I have my old setup for sale. I have pm'ed you with what I got :D
Haha change brake pads ebc yellow or A1RM by qfm, some RBF 600 or 660 brake fluid then well setup coilovers and you will beat him
Edit - when you beat him with 200kw he will be crying and Mallala is a brakes track too so having 320kw without touching his brakes he will be trying to stop at 300meter if you sort good brakes out oyou will go deeper
Hey na he wonts to do the burn out pad drift and drag. I cant do drift or the skid pad even when my tc is of my car still stalls at highish rpm its auto aswell. So was thinking shift kit prob cant afford a bigger turbo. I have cusco coil overs and i ended up geting those starcorp wheels they fit real tight but i can feel there heavy as f**k. Yer and this all stared cuz i beat him at mario kart lolol
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
