Hey all i no this has prob been covered iv tryd finding/reading but i just dont understand it
Iam looking at new wheels for my r34 gtt and have found these
18x8 +45 5x114 with 225 tyres i really have no idea what this means apart from 18inch and the tyre size
So will these fit my car nicely with out sticking out the guards or to far in.
https://www.sau.com.au/forums/topic/419192-need-help-asap/
Yer there the same size as stock. just 18s so new question
Right above my stock wheels there somthing idk what it is but i assume its something to with steering and my stock wheels are about a inch or less away from the rear gards so would that make the 18s a no go with out gard rolling i have cusco coils but i dont think my cars that low or i can get drift teks the same size as the stock gtt wheels but there gold and my cars white what use think
Links to adds http://www.gumtree.com.au/s-ad/morphett-vale-area/wheels-tyres-rims/koya-drifteks-gold-for-sale-or-swaps-/1012053457
http://www.gumtree.com.au/s-ad/highbury/wheels-tyres-rims/18-x-8-45-5x-114/1012307623
Edited by gts25tnissan
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735108
225's are damn skinny the rear will break loose easy and fronts push out on power too soon , like uturns under power without a clutch kick lol
My fronts are 245 ,rears 285 on 18's no hitting at all if your not dumped in the weeds
and your alignment is setup properly
And the offset is near stock cfr what stock was?
If you can get a few fingers between your front gaurd and tyre your prob ok unless you hit a pot hole while turning or curb driveway at full lock
if anything bend the inner lip of the guard near the top , folded it tighter just a bit so the tyre wont grab it and flog it , make sure the liner is held up properly too
Edited by Carbon 34
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735198
If the offset is higher than about +35 the wheels will more than likely hit your suspension anyway. A 9j +20 will sit nice and flush with the front of a 33 and the rear can go a little lower in offset or higher in width.
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735616
Ok last try i found some more gumtree add is http://www.gumtree.com.au/s-ad/parafield-gardens/other-parts-accessories/street-drift-race-rally-items-no-longer-needed/1013603913 was looking at starcorps and sorry krishy dont realy wana go to stock would rather save till next payday but then the missis and the hole u spend more on ya car then me lol
Sorry just ead petes post they wont fit grrr whys there no rims on gumtree when i have some money there always is when i have none
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735764
Hey all my mate wonts to race me at malla nats in november i have a r34gtt with fmic pod and 3inch turbo back. He has vt ss with 320kw at the wheels so he says. hes mods are maffle tuned port and polished head and a milled cam prob a few more i stop listening after awhile. what mods do i need to make that sort of power. I have about $1500-2000 to beat him lol.
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740519
Haha change brake pads ebc yellow or A1RM by qfm, some RBF 600 or 660 brake fluid then well setup coilovers and you will beat him
Edit - when you beat him with 200kw he will be crying and Mallala is a brakes track too so having 320kw without touching his brakes he will be trying to stop at 300meter if you sort good brakes out oyou will go deeper
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740578
Hey na he wonts to do the burn out pad drift and drag. I cant do drift or the skid pad even when my tc is of my car still stalls at highish rpm its auto aswell. So was thinking shift kit prob cant afford a bigger turbo. I have cusco coil overs and i ended up geting those starcorp wheels they fit real tight but i can feel there heavy as f**k. Yer and this all stared cuz i beat him at mario kart lolol
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740643
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
