Hey all i no this has prob been covered iv tryd finding/reading but i just dont understand it
Iam looking at new wheels for my r34 gtt and have found these
18x8 +45 5x114 with 225 tyres i really have no idea what this means apart from 18inch and the tyre size
So will these fit my car nicely with out sticking out the guards or to far in.
https://www.sau.com.au/forums/topic/419192-need-help-asap/
Yer there the same size as stock. just 18s so new question
Right above my stock wheels there somthing idk what it is but i assume its something to with steering and my stock wheels are about a inch or less away from the rear gards so would that make the 18s a no go with out gard rolling i have cusco coils but i dont think my cars that low or i can get drift teks the same size as the stock gtt wheels but there gold and my cars white what use think
Links to adds http://www.gumtree.com.au/s-ad/morphett-vale-area/wheels-tyres-rims/koya-drifteks-gold-for-sale-or-swaps-/1012053457
http://www.gumtree.com.au/s-ad/highbury/wheels-tyres-rims/18-x-8-45-5x-114/1012307623
Edited by gts25tnissan
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735108
225's are damn skinny the rear will break loose easy and fronts push out on power too soon , like uturns under power without a clutch kick lol
My fronts are 245 ,rears 285 on 18's no hitting at all if your not dumped in the weeds
and your alignment is setup properly
And the offset is near stock cfr what stock was?
If you can get a few fingers between your front gaurd and tyre your prob ok unless you hit a pot hole while turning or curb driveway at full lock
if anything bend the inner lip of the guard near the top , folded it tighter just a bit so the tyre wont grab it and flog it , make sure the liner is held up properly too
Edited by Carbon 34
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735198
If the offset is higher than about +35 the wheels will more than likely hit your suspension anyway. A 9j +20 will sit nice and flush with the front of a 33 and the rear can go a little lower in offset or higher in width.
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735616
Ok last try i found some more gumtree add is http://www.gumtree.com.au/s-ad/parafield-gardens/other-parts-accessories/street-drift-race-rally-items-no-longer-needed/1013603913 was looking at starcorps and sorry krishy dont realy wana go to stock would rather save till next payday but then the missis and the hole u spend more on ya car then me lol
Sorry just ead petes post they wont fit grrr whys there no rims on gumtree when i have some money there always is when i have none
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735764
Hey all my mate wonts to race me at malla nats in november i have a r34gtt with fmic pod and 3inch turbo back. He has vt ss with 320kw at the wheels so he says. hes mods are maffle tuned port and polished head and a milled cam prob a few more i stop listening after awhile. what mods do i need to make that sort of power. I have about $1500-2000 to beat him lol.
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740519
Haha change brake pads ebc yellow or A1RM by qfm, some RBF 600 or 660 brake fluid then well setup coilovers and you will beat him
Edit - when you beat him with 200kw he will be crying and Mallala is a brakes track too so having 320kw without touching his brakes he will be trying to stop at 300meter if you sort good brakes out oyou will go deeper
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740578
Hey na he wonts to do the burn out pad drift and drag. I cant do drift or the skid pad even when my tc is of my car still stalls at highish rpm its auto aswell. So was thinking shift kit prob cant afford a bigger turbo. I have cusco coil overs and i ended up geting those starcorp wheels they fit real tight but i can feel there heavy as f**k. Yer and this all stared cuz i beat him at mario kart lolol
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740643
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
