  • Replies 55
ya i'm frantically looking around for a reasonable insurance company,,, coz the car might get here from cairns either on friday or monday,,,
anyone got any contacts with insurance ppl , i.e discounts,,,, any way i can put it under my dad's name and get a cheaper quote,,,?
i did that with the r33,, but can't get insurance for a r34 with that insurer ,,
the rims are just series II rims,,, i wish they were gtr!! lol,,, only 17" rims,,
They look like GTR rims :P
Welcome Afro.
I suggest you try the normal ones. Depending on age, you can try Suncorp (if you are over 25) or Famous Classic Car Insurance. They kinda do deals for SAU people. Theres a thread on here about them. Just search for Famous Classic.
Or Just Cars... Young and Cool. Most of them charge through the nose. But it depends on how much you want you car insured for as to whether you want to pay the premiums.
THANKSS,,,, :P
I"ve read a few threads< and from what i can figure out<< some ppl are paying around $1500 - $1700 for r34's while others are paying about $2400,, i can't figure out y they vary so much,
anyways, i'm gona call a whole heap of places tomorrow,, and see if i can get a better deal,,
Hey AFRO,
beautiful car mate, as you can see from my avatar, it's the car i want, but unfortunately my budget couldn't stretch to a 2000 model (year Nissan started producing TV2 GT-T's) so i've just bought myself a 1998 Black R34 (but most prob get full respray to TV2 as there are a SHITELOAD of black R34's in Melb! :P :P)
I rang Just Cars, they quoted me $2467 - 20 yrs old, no bad history at all (touch wood), rating 4. Unfortunately no monthly payments.
And for those wondering about the rims, there are a few differences between SI and SII R34's.
Interior: Two tone (whitish, kinda more cream, and normal black colour) steering wheel and gear knob.
Exterior: Different front bar (altho AFRO's is an Altia item) Darker rims, more GTR colour.
Engine: More torque, not sure exactly how much, bout 20nm prob.
Differential: Helical as compared to Viscous from the SI
I think that's about it.
Congrats on the car mate, and that is an AWESOME price too! Wish that car was advertised more widely, i would have definitely be contesting you for it!
cheers.
Hey AFRO,
cheers.
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
