  • Replies 68
If your car is not making huge power and your have pads that have over 50% pad left you should be ok for your first time. Just make sure you keep an eye on your pads as they can wear down very quickly at Mallala. QFM A1RM's were good for 1.20's in my car, they work great.
As everyone says, keep an eye on your pads, if they're low then source something spares locally. Running old stock stuff ya probably won't put that much load on the car anyway, which OS good, just don't be suprised if your pedal goes to the floor
In the medium term I wouldn't get too precious about your rotors, you'll soon be throwing them in the bin. I still run sporty street crap and they crack after a few good session. Works out economical for me to replace every 4 track days when the pads are low, they're cheaper than pads! As for pads, I've been using pmu club racers and love them. (if ya run out of pads I've usually carry old spares anyway)
Motul fluid seems to be a popular choice, been using the 660, but running 600 now as it's easier to source when ya need it.
Ps: garages used to be $30 payable to the dude on the pushbike.
I expect I will learn about alot of shortcomings in my brakes, suspension, tyres ..... well the whole car really !
Being my first time out I wont be laying down very good times, therefore not really fussed about what I am using this saturday in the way of pads, fluids etc.
Pretty keen to just get out there and have some fun, I will worry about improvements for the 23rd of March.
Well I was about to put the car on the trailer late last night and discovered I got a bad fuel leak . Upon investigation it seems a fuel line split which would have meant hours lost getting and fitting another. At $100 + $35 for garage for maybe only half a days track work I decided to sit this one out.
23rd of march is the next goal , gives me time to get brakes machined , new a1rm pads and fluid.
Maybe even treat myself to some coil overs .
Hope you lads have fun .... Sad panda
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
