  • Replies 68
They held on thanks Nick, though they were 2 lefts, and there is still a bit of groove on them so might get another practise out of them :thumbsup:
Ah cool greeny if I had of known you were sau more of us would of said hello
Spewing I couldn't get out there , thinking about it more even if I had fuel hose on the night I'm not sure I would have wanted to put a car on a race track that just had fuel squirted all over the diff and under the rear of the car ...
May have been a recipe for disaster , nevertheless I hope to get out there on the 23rd of march now if you lads wanna join me !
Guys if your super keen on getting out on the track and can't get your car out there, hire one of mine!! Prepped and super fast they won't disappoint !!
Whats the rates mate?
Guys give me a call for more info, I hire them out for any and every event or private day, and the prices do vary depending on things like tyres or type of event, but base rate is $250 for half day or $440 for a full day, no limit on how many people use the car on the day
0433368063
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
