  • 6 years later...
2 hours ago, Milhouse said:
What has happened to the price of e85 in Canberra!? It used to be cheaper than 98 and now it is almost 40c per litre dearer...!
I would say nothing happened to the price of e85 , Did the price of 98 go lower?
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7933561
On 17/06/2020 at 9:13 AM, Steve85 said:
Six and a half years. Not a bad dig up.
If you are converting your car to E85 for the fuel savings you're doing it wrong...
He he yep I did a search and this thread came up. Nope not looking for savings but just though last time I checked that was cheaper than 98 but you use allot more of it anyway but now can’t believe how much more expensive it is! But probably doesn’t have a big market in Canberra with only 2 servos selling it so got to be expected..
  • Like 1
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7934183
You did a search? No one searches... Cue: the same question over and over... :D
I must say, i'm very spoiled being in Melbourne. There's United E85 dotted around in most locations. I feel bad for the rest of the country though... :( Good thing too my range is about 150km.
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7934185
  • 4 months later...
it USED to be cheaper, but the market dropped out of it, and they realised performance peeps would still pay for it.
Now Caltex doesnt sell E flex, makes even more sense, as they have a monopoly on the market.
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7942836
It also needs to make financial sense for them to stand by it, it's a low turnover product with an expiration. If I was buying a product in bulk that was going to sit there and go off while very few people buy it, then I would be covering that risk by charging a premium for it.
I just feel there isn't much reason for anybody to complain about it, flex fuel is so easily achievable that if you're running a high performance street car on dedicated E85 then that's really nobodys problem but your own. And if you only use it for the track, then it isn't that expensive that it makes a big difference compared to tyres and track hire. Personally I'm happy to pay the going rate for it if the alternative is that it's taken off the pump and we have to go back to ordering in 200l drums from Sucrogen.
  • Like 1
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7942838
Adding ethanol to 91 reduces the price.
Thus, Ethanol is cheaper than ULP 91 fuel. by a significant margin too.
Add more than 10% of it though, and it is somehow massively more expensive.
For that reason alone they can get f**ked. I am glad I'm on 98.
https://www.sau.com.au/forums/topic/419241-e85-act/page/3/#findComment-7942840
  • 1 month later...
  • 4 months later...
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
