Up for sale is my 1999 nissan stagea 260rs [genuine autech version]
I have owned it for two going on three years now and think its time to move on. Since owning it I have resprayed it sliver [standard colour] just to neaten it up as when I got it their was a few scratches and dent here and their. I have also spent a fair bit on it to get it where I wanted it.
The engine has been fully rebuilt with the following done:
-valve service cylinder head
-machine tappet shims to specs
-260 tomei poncam camsharfts
-JE forged pistons
-bore and hone
-h series bearings
-all hoses were replaced
-nitto metal head gasket
-nitto intake gasket
-nitto exhaust gasket
-apr head stud kit
-new standared thermostat and gaskit
-all fan belts
-35r garret turbo and waste gate [plumbed back]
-turbo benni
-custom exhaust manifold
-200 cell high flow cat
-custom 4inch exhaust with 2xmagna flow mufflers to keep it legal
-hdi intercooler [i think cant remember]
-1000cc injectors [not sure of brand]
-walbro 400lph intank fuel pump
-adjustable cam gears
-hdi electronic boost controller type r
-evo boost gauge
-2xdrift pod filters
-hks induction pipe kit
-clear timing belt cover
-new timing belt
-nistune ecu
-jjr oil catch can [return feed so you don’t have to empty]
-hcb heavy duty clutch
-clutch assy cylinder + hose
-power steer rack was pulled out and serviced because of leak
-smoked side indicators
-19inch prodrive seven spoke grey rims [little bit of gutter rush from previous owner]
-head light eyebrows [keeps the lights from going yellow]
-some sort of immobilizer [not sure of the brand came with the car]
The car made 339.4kw @ all 4 wheels but I was only running bp95 and an air flow meter was playing up,since then I have replaced an air flow meter but just haven’t had time to get it retuned!
The engine has been built to handle over 450kw and can be achieved by upgrading to spitfire coil packs with a retune a new ecu may be needed depending on how much more power you want.
The car is immaculate inside and out apart from the front and rear bars which will be resprayed due to them having some scratches
I have also put new bridgestone 245/40/19 tyers all round
The car gets serviced EVERY 5,000kms religiously!
Rego 20th September 2013
Alot of time effort and money has gone into this car for you to enjoy!
I have all receipts and dyno sheets
The car has just clicked over 100,000kms
The engine has done 5,000kms
Im asking 27,000 which I think is a fair price
NO TIME WASTERS PLEASE
ONLY I WILL BE DRIVING UNTILL DEPOSIT HAS BEEN TAKEN!
LOCATION SYDNEY NSW 2100
i will add photos tomorrow
also a few things i forgot to mension
-comes with nismo floor matts
-tinted front windows to match the back
- the rain strips have been painted black to get rid of the god awfull purple colour that they turn
-roof racks that i havent had the need to use yet
-standared brembo brakes
-and comes with cargo net & blind
Having personally been in this car a few times, I can certainly vouch for its cleanliness and power.
Whoever buys this will be VERY happy with it, no expense spared.
Edited by XS80ST
  • 1 year later...
ok car is back up for sale again. I have since resprayed both the front and rear bumper bars due to scratches
and have also purchased a plastic dayz front bar which was also sprayed and fitted to the car to replace as the autech front bar as it is fiberglass.
I still have the autech front bar wrapped up in mint condition to be sold with the car. I have also put 22mm spacers back and front [wheels] to give the car a better look
the car now has 113,xxxkms on it reason for selling is I have bought a motor bike as a daily so the car just sits in the garage under a cover most of the time now
price $27,000
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
