I'm not surprised....and I am also relieved....everything is saturated and the traffic mess that will occur this afternoon won't be fun.
A little disappointed as I pushed hard to get my car finished today. On the bright side, I am off to pick it up now :)
  • Replies 249
One of our most tasty R34 GTR's can't make it due to the schedule change. Somebody else have an example worthy of being on the official SAU trade stand? PM me your details (pic too if possible). Must be able to register VIP and be there @ 4:30 sharp.
Ok, so here is THE PLAN!
(Huge thanks to NXTIME for finding and scouting the location for us!)
A member has a contact that works in this business park. It has been verified to be pretty much empty by 5:00 pm on a Friday and has tons of room for the SAU crowd. We don't know if there will be other groups meeting there (since this is a public event) but it easily accomodates between 80 and 100 cars.
It goes without saying that anyone revving their engines, burn outs, loud music or generally bad behaviour will be asked to immediately leave and will be reported to the authorities. Being in this group you are representing SAU:NSW and our code of conduct, member or not.
Two groups probably means that the SAU entries in the mega meet will be in at least two locations, assuming they park the mega meet cars first come first serve. VIP's will be in one group and general entry in the other.
Group 1: VIP's and SAU Trade Stand Entries (we only have room for about 8 on our trade stand and they have already been identified)
Meet up at the location at 4:30 and will be departing at 5:00 pm SHARP to go the few minutes to the Mega Meet location. A small group of execs/trade stand members will depart earlier to report back on the entry conditions. This MAY require earlier departure time if queuing is bad.
SO BE PREPARED TO DEPART ANY TIME BETWEEN 4:30 AND 5:00 PM!
Group 2: General Entry should arrive to the meet location between 5:00 and 6:00 pm. Group two should depart the location at 6 PM sharp!
If the groups get split by the traffic lights there isn't a whole lot we can do as we expect the whole area to be chock full of cars trying to get to the meet. So do your best and don't try any funny business to stay together.
As long as the groups leave together we can try to reassemble in the meeting parking lot.
Expect a long queue and to be sitting on idle for a while.
TIP! Be sure to check your radiator fluid to make sure your car won't over heat.
MEETING LOCATION: Industrial Car Park off Holbeche Rd & Walters Rd, Arndell Park (Meeting will be in the Red Triangle marked on the map)
DO NOT enter from Holbeche Rd as that driveway is steep and crested. The two driveways on Walters Rd are lip/exhaust friendly, with the on on the lowest part of this picture being nearly flat.
So we are stIll meeting at this same place and time this Friday?
Yes, still meeting there. Most cars can get in via the 'northern' Walters Rd driveway (wide enough to enter at an angle to avoid scraping). Any very lowered cars should use the 'southern' Walters Rd entry 40m further down if you have any concerns.
Also, VIP Entry is via the Sydney Dragway Spectator Entry gate which is the second entry when heading south on Ferrers Rd
General Entry is via the Sydney Dragway Competitors Entry gate (as per the map above)
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
