  • Replies 249
emailed top secret to see if it's possible to rock up before 6:30 if you have a VIP ticket so you can try to beat the rush for any of the local guys.
I'll update here if I get an answer
The ticket says that the VIP ticket gets u in at 5:30pm
ah ok I haven't opened my email yet from my order, oh well I didn't specify the time in my email to tsi so maybe can get in earlier? worth a shot :)
Depending on how many SAU members are going, there are a few ovals near eastern creek to meet up before hand
One that I think should be open around this time is Karella Reserve - http://goo.gl/maps/X9sMi
There is another one down the road across from Blacktown Olympic Park but the gates may be closed
I live not to far from there so I can check them out this friday night and see if they're open
It's on Historic rego, So i'd bet that the Mega Meet doesn't have a Cams number for the event :(
think outside the box.
take regod plate off skyline.
fit to fiat.
cops go past, scan plates, shows rego, all sweet.
you think at a glance they're going to check the make/model of the car?
it will probably attract less negative attention than the skyline.
remember, you don't need stickers any more.
fit to fiat.
And advertise it on a public forum... U sir are a genius :P
fit to fiat.
Lol, my rego has some nasties associated with it, then they will see "black" rego plates on a Orange Fiat..
I'll pass haha
ill be there if the car is sorted out on monday.
Hope it is! More SAU there the better :D Sounds like it will be a big meet! Just hope it all runs smoothly as that is a farkload of cars to handle!
depending on the direction you come from
there's the servo on the corner of great western highway & brabham drive, it's got decent space for a few cars to meet beforehand & go to the gates as a group from there.
or eastern creek tavern a bit further down
That servo is no good PJ as it's on the wrong side of the traffic island. I have been thinking maybe one of the side streets in Huntingwood as the streets are quite big & with ample parking. Everyone can then organize themselves. A good point by k_d in the ACT section too: RMS, Police & possibly EPA might have a 'station' set up. :angry:
Guest
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
