my r33 has only have 4 seatbelts and therefore was compiled as a 4 seater although i was wondering how much effort it would be to throw a lapbelt in the back and make it a 5 seater legally/
had a search on vicroads website and it says if its a factory option then it doesnt have to be engineered.
even called vicroads for clarification but the dude was a kent and just said look online.
someone must of done this before any info would be appreciated
https://www.sau.com.au/forums/topic/419325-4-to-5-seater/
Skylines were all 4 seaters from factory.
are you sure? i thought some came as 5 seaters, i know theres a thread with people being suprised to find a seatbelt tucked under the seat after being compiled as a 4 seater. mine just has two bolt holes which came from factory so im thinking it couldve been an option
https://www.sau.com.au/forums/topic/419325-4-to-5-seater/#findComment-6737739
If it's a coupe, to my knowledge they're all 4 seaters.
https://www.sau.com.au/forums/topic/419325-4-to-5-seater/#findComment-6739166
huh.
my r34 GTT 1999 coupe has 5 seatbelts. sure, i'm the second owner in australia but to my knowledge that middle seatbelt in the back is factory.........
maybe i should check when i get home today :whistling:
Edited by darksky34
https://www.sau.com.au/forums/topic/419325-4-to-5-seater/#findComment-6740207
well i know theres a few threads of people saying they found middle lap belts hidden under the seat and mine defiently has factory mounting points so im leaning towards thinking there mightve been an option.
https://www.sau.com.au/forums/topic/419325-4-to-5-seater/#findComment-6740508
My R33 GTS-t is a 5 seater with 5 seatbelts (and two 4 point harnesses, rendering the rear seats extremely uncomfortable :laugh:). I have pulled the seat out enough times to know that it isn't hard to forget to pull the middle belt up on reinstallation.
GT-Rs are all 4 seaters I believe
https://www.sau.com.au/forums/topic/419325-4-to-5-seater/#findComment-6740538
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
