I saw those on ebay (they come in other colours as well) and I was wondering who would be the first one in the Skyline community to have one on there car - I should have guessed it would be Duncan :bunny:
haha that is pretty bright. maybe fluro orange te37s?
on a more serious topic, we got our hands on these the other week and installed them over the weekend. Blitz ZZR setup
Hopefully none of this was important....can't read a word
The install was easy (and damn, how much cleaner is an electric car with 3,000klm compared to a ute with 500,000klm!).
Excellent improvements, it's gone from a soft and rolly hatchback to reasonably acceptable handling.
Interesting question mate...and over time I should be able to answer it. The carwings setup records each journey and average economy, so I should be able to compare pre and post suspension change once there is a decent amount of average data
This setup is 30% lighter (and you would normally count half the suspension as "unsprung") and 30mm lower which would both normally help economy.
But the interesting thing is, pretty much everyone is interested in the range and impact on range of doing things to this car. If you take a step back, who here has ever thought twice about fuel economy before changing shocks? or an airbox, exhaust, cooler etc etc. To me the car can be improved for my preferences by modifying it instead of sticking with the factory compromises. If I have lost 1-2klm (1%) of range from any given change it is kind of irrelevant. I am more concerned about when I change the tyres from eco to grippy ones, that could have a 5 or maybe even 10% impact.
I suspect I will get less range now because it is much more fun to drive fast ;)
What is this thing called fuel consumption????????
If you drive a performance car fuel consumption is the last thing on your mind.
Not necessarily.
I see cars all the time that just have a "full power tune" where the tuner has just kept hitting the 'up' button until it was running 10:1, and then passed it off as a "safe" tune. My fuel gauge goes up when I follow those cars because they spew out so much unburnt fuel (ok, slight exaggeration).
While it's absolutely unavoidable that you have to burn fuel to make power, and a more powerful car will drink more when you are up it, there's no reason why you should be wasting fuel willy nilly, unless you're really pushing extremes in which case it's barely a road car any more.
Nothing to do with my car....but this is an interesting idea: http://smh.drive.com.au/motor-news/formula-ones-electric-rival-20130516-2jp0h.html
Very interesting. Watching the EV industry to see what after market industry springs up. I expect adoption of EV to happen very quickly for suburban commuting, as the dumbing down of drivers continues.
I like where you're going with your build. Keen to see where it takes you.
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
