  • Replies 74
  On 07/02/2013 at 12:46 PM, EM1 said:
One question ,If you got the tomei dumps and manifolds ceramic coated inside and outside would that help protect them.
In theory it should
Rapid changes in temp contribute to manifold crack. The ceramic coating should greatly reduce heat transfer and allow for slower heating/cooling cycles reducing thermal shock.
  On 07/02/2013 at 12:57 PM, wedge_r34gtr said:
In theory it should
Indeed.
Along with weight of exhausts poorly hung and movement of exhausts as well when used on circuit, another big factor.
Typical street driven cars don't seem to crack them. It's the guys doing circuit or 400rwkw+ and solid driving that seem to kill them. Your 350rwkw street car would probably be fine... But then... Stock manifolds are fine for that so why bother really? :merli:
Go with stockers, reliable and cheap! (Breaking a Tomei set makes people cry as you gotta take the turbo side out to fix/replace).
  On 07/02/2013 at 6:42 PM, levinboy said:
-9s 350kw on 98 built 2.6 full boost 22psi by 3800rpm earlier depending on weather
Don't you remember the ride I took you on...
i do and it was awesome still brings a stupid grin to my face i just think its going to be way to hard for me to get everything perfect to get it setup like yours to make the power i want i dont want to get to the end of my build and be dissapointed :unsure:
As i keep saying - you've got a LOT more to put into the driveline/suspension yet. Nick has a well sorted set-up and that's what makes it fast in the roundy roundy stuff, not just the power (which is still good) of course).
My R33 R was SOOooooo much more fun to drive, and faster, with the suspension/brakes/diffs/transfer case all done. So much so that if I was doing another build I'd do all that first before going for power. I drove a mates R33 R without decent suspension/diff/transfer case and it was nowhere near as fast as mine. Both cars had similar engine builds/brakes/power
im worried about getting the ceramics off the engine bay as a first priority then im sorting the suspension
  On 08/02/2013 at 12:29 AM, R31Nismoid said:
Yeah that is always a good idea (I more meant building motors and what not, should've been clearer :))
haha im trying to plan forward so what i buy now will be applicable when i start to build over engineer so stuff dosnt break
IMHO response and all thar fluff costs thousands and adds a few kws to the party. Just get a good spread of power and spend the thousands you have just saved on actually punting the car at the occassional track days
This got it right on page 1
  On 05/02/2013 at 3:17 PM, R31Nismoid said:
Prime example here in Vic is everyone said you needed 380rwkw to get a GTR into the 'teens' at Sandown. Then one day it was done solidly with 330rwkw and full weight. It came down to the things mentioned earlier - and a driver with experience and knowledge of his car :)
Put -9s on (so its still responsive around town), and spend time/money in getting the car sorted in the more important areas - especially seat time, as you'll chop times consistently for years In most cases especially as you develop the car. Enjoy milling over that for the next month lol :merli:
Only his reasoning for improved times is wrong :) It had more to do with the tech of tyres and change from RE55s to AO50s. The change from 98-100ROn to E85...those two factors alone mean there is no point comparing times...not to mention the final factor that tracks are being re-surfaces. Sandown is faster simply because of re-surfacing and now PI is >1.5seconds quicker due to re-surfacing.
But to the core of the question. The things that increase response. Well everything is a compromise and trade off. But the main things are to reduce inertia so smaller lighter materials for things like turbo wheels, tailshaft, accessories on the front of the engine. Reponse comes from good culinder filling and gas velocity so as others have touched on dont go crazy big bore on inelt pipes and headwork.
If you want Mines like response just put 2 stroke/rotary like gearing in your car and the need to swap gears every 2 seconds will have you thinking you are driving the most responsive car in the world :) But silly statement but raises the intersting point is to look at gearing and diff chanegs are an option.
If you are talking engines then bin the head. Get an RB25 R33 or R34 head, put an built for purpose inlet manifold on the car and just jam fist fulls of boost into it
There is every point. It's the whole point about car development over time and making improvements in various areas. If tyre changes simply meant no point, then why bother even comparing anything? Tyres are always going to evolve just like car set-ups.
Go back 5-6 years then with AO50s and resurfacing - those times still wouldn't have been done as there is still improvements being made, such is the nature of developing a car.
Yeh, its always a matter of factors. But the 3 biggest factors are tyres, track and E85...so car development is a far smaller variable. Take them off E85 and put them back on RE55s if you want a good indication of just how much the cars have really developed
  On 11/02/2013 at 12:20 PM, vorse said:
come on guys there must be other ways to get more out of the bottom end im curious and want to learn
How's your bank account look?...VCAM is another option...
or rather than chasing the power at low rpm, what about lightening the rotational load (carbon shafts, carbon clutch etc) to help response
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
