Hey guys I have an R34 GTT and when I turn on my aircon my revs drop massively, causing my car to stall at lights and such. I disconnected the AAC Valve and connected it directly to 12v with the aircon on and the revs will jump up to 1200 from ~550rpm. Which is where it should be sitting. I have checked at the ECU and it doesn't have any power coming out to the AAC. Even though with the scan tool it says AAC at ~100%.
The car has some weird rev drop when I start the car even if the aircon is off.
Any ideas would be appreciated!
https://www.sau.com.au/forums/topic/419347-aac-valve-not-getting-power/
Check for 12V at the AAC plug. Should have constant 12V on one pin with the ignition switch on. ECU controls the ground for the AAC using a PWM output when the engine is running
AAC valve itself could be faulty.
After looking at the wiring diagram if the AAC doesn't have power, the Canister purge control valve, variable air intake control solenoid valve, turbo pressure control valve and air jet swirl control valve shouldn't have power either?
The AAC Valve itself is fine. I tested it by running 12v directly to it and the revs picked up drasticaly.
For some odd reason when ignition is on it has 1.4v once the engine is running with A/C on it has 0.01V????? What is going on here!
Edited by sirjb
  On 06/02/2013 at 8:52 AM, sirjb said:
After looking at the wiring diagram if the AAC doesn't have power, the Canister purge control valve, variable air intake control solenoid valve, turbo pressure control valve and air jet swirl control valve shouldn't have power either.
Correct, but if its just the part of the loom that controls the AAC valve that is damaged then only the AAC valve won't work.
I'm not sure if that circuit is powered from a dedicated fuse? Quite possible 'Engine Control' Fuse at 10A? I'm not familiar with the body loom of an R34, only the engine side of things.
02 Sensor won't have power either, the air jet swirl valve and variable intake control valve would only be on DE's i would say.
So I got a good multimeter from work and did some testing. When the ignition is switched to 'on' with the engine off, there is 12v to the valve, but there is no ground continuity. Once the engine has been started the 12v disappears and the continuity of the ground is all good. SO for some reason the 12v is dropping out once the engine is running, any ideas?
Edited by sirjb
  • 1 month later...
  • 1 year later...
Hey guys, Well it looks like my aac valve isn't working correctly or God knows what it is, I apply 12v to the solenoid and nothing changes, I also have a spare solenoid here and when I apply 12v to it nothing happens??? is it meant to move in and out or something? please let me know asap, thanks.
Complete circuit (12 V source to solenoid to ground)?
pull the solenoid off the valve and have a look. You should feel it work if you hold it while applying and removing 12v, its only held on with 2 little screws
Because they work off frequency (PWM) you will not be able to do much more then see if it functions. It shouldnt matter which pin you apply 12V to, as long as it has a circuit to ground on the other pin.
Hey man thanks for the quick reply, yeah I apply a positive to 1 pin and 1 negative off my booster pack onto the pins and nothing happens and I can't feel it doing anything, or do I have to do it with the car power so that I can put a earth instead of negative if that makes any difference? thanks.
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
