Hey Guy and Gals,
It has come time for me to part with my beloved BBS LMs
The size is 17x9 +5 in 114.3x5 stud pattern
These wheels started their life as 17x9 +20, but the specs were a little weak for my liking, so i reverse mounted the faces and cleaned up the dish
The reverse mount face gives the wheels 15mm less offset and more dish
These wheels clear R32 GTR V-Spec brakes(not sure if they clear R33 GTR Brembos, but caliper spacing suggests that they should)
There is a bit of gutter rash on a couple of the wheels, but stuff that can be pretty easily repaired
The paint on the centers is pretty good with only a few stone chips
These wheels retail for over $1400ea new, so I'm pretty firm on the price of $2.5k
The reason for sale is I bought a couple of new sets of wheels(for a new look) and could use some money to clear some debt.
Would consider trading for wheels of similar value in more aggressive specs, but would prefer a cash sale.
Wheels Located in west side of Melbourne, VIC
If you've got any questions call or sms to 0430131020
https://www.sau.com.au/forums/topic/419374-bbs-lm-17x9-5-vic/
  • 1 month later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
